September 25, 2018, 11:48 |
Output Forces Using interDyMFoam
Emily
Rep Power: 8 |
**EDIT: I just managed to solve this problem. As usual all it takes to figure it out yourself is asking for help. Instead of deleting I'll say what I changed in case it would be useful for anyone else. The problem seemed to come from the fact that I had not specified the CofR. I assumed it would not be needed because I didn't need moments and based on documentation I thought it was optional, but forces seems to need it to run. After a few more modifications to get the logging interval I wanted, the code now looks like this: functions { #includeFunc residuals forces { type forces; libs ("libforces.so"); writeControl adjustableRunTime; writeInterval 0.01; patches (walls); rho rhoInf; log yes; rhoInf 1000; CofR (0 0 0); } } End of edit** I'm very new to OpenFOAM and have been trying to get a basic slosh simulation running using interDyMFoam. To get myself up to speed, I've been using the slosh tutorial files as examples, but my geometry is just a simple cube in an attempt to reduce errors. I need to output the forces on the walls exerted by the slosh, but keep getting errors when trying to do so using all examples I've found. Right now I'm trying to use this in the controlDict file: functionsBut I've been getting this error every time: keyword origin is undefined in dictionary "C:/PROGRA~1/BLUECF~1/ofuser-of5/run/cubetest/system/controlDict.functions.forces"At the suggestion of someone else's post, I've been trying to run the simulation using blockMesh, setFields, then interDyMFoam -postProcess. The last command was said to produce fewer errors and sometimes work better with forces than using a run file similar to the tutorials. I've also tried using #include "forces" in the controlDict file with a separate forces file written the same way I currently have it written in the controlDict. This was based off of the propeller tutorial. I received the same error message after trying this. I haven't been having much luck finding alternative examples or suggestions to try so any help would be much appreciated. Since I'm new to the program, I'm sure it's something simple that I either forgot or misunderstood. In case it's needed, I'm currently running version 5 of OpenFOAM. Thanks in advance! Last edited by spaceplumber; September 26, 2018 at 12:59. Reason: Solved problem |
Full-scale ship case with velocity using interDyMFoam show unrealistic trim angle!! | lil_star | OpenFOAM | 0 | December 4, 2017 14:00 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 07:16 |
Viscous forces (interDyMFoam) differ between OF 2.0 and later versions | maxof | OpenFOAM Running, Solving & CFD | 2 | May 30, 2013 05:17 |
Strange torque calculation | danny123 | OpenFOAM Running, Solving & CFD | 5 | May 7, 2013 05:59 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 15:09 |
