Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Merge time folder for pimpleFoam case run in two separate PCs
Old   September 22, 2018, 16:07
Default Merge time folder for pimpleFoam case run in two separate PCs
Ruonin is on a distinguished road
Hi folks,
I find myself in a bit of a pickle and failed to find an answer in the forum.
I have a pimpleFoam case which I partly run in to different machines.
Let's say, for time 0:5 seconds I run it parallel in a 2 core laptop with 0F 4.1.
Since this was taking a considerable amount of time I copied the last time folder and decomposed it to an 8 core machine running OF2.X (I cannot recall the exact version at the time) and run it until 10 seconds. Probably not a smart move...
Now for the issue:
After reconstructing the times for both machines and copying the time folders to just one case I get an issue when post-processing in Paraview.
If I use the "constant" folder for the first case (0 to 5 seconds) the data for the remaining time folders is non-sense (probably mesh issues) and vice versa.
I know I can post-process the cases separately but I would prefer to join all time folders to create an animation.
Also, I think I've done something similar in the past but cannot remember how I got around it...
As anyone experienced something like this or has any ideas?
Best.
Ruonin
Ruonin is offline   Reply With Quote
Old   April 24, 2019, 07:59
Bump!
Anyone has experience with this?
constant, folder, pimple. openfoam, time
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
