Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
successful compilation of new function object BUT nothing is written in time folders
Old   August 19, 2018, 01:42
Default successful compilation of new function object BUT nothing is written in time folders
K
mkhm is on a distinguished road
Dear foamers,
I am trying to create a new post-processing tool. To do that, I followed this tutorial: http://www.tfd.chalmers.se/~hani/kur...CFD_Report.pdf . I can compile successfully but nothing is written in my time folders. I tried to copy one of the case in OpenFOAM-4.x/src/functionObjects/field/, give it another name, change the name in .C and .H file and mention this name in "file" located in OpenFOAM-4.x/src/functionObjects/field/Make/. No success. There is no compilation error and when I run rhoCentralFoam -postProcess -func newFunction as a command line, the necessary fields are read but nothing is written. To be more precise, when we execute for instance MachNo, we have :
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
functionObjects::MachNo MachNo writing field: Ma
In my case withe newFunction, the line "functionObjects::MachNo MachNo writing field: Ma" (with Ma or MachNo = new names) is missing.
I tried also to include the following line in my controlDic:
functions
k
// Type of functionObject
type k;
// Where to load it from (if not already in solver)
libs ("libfieldFunctionObjects.so");
// Function object enabled flag
enabled true;
// When to output the average fields
writeControl writeTime;
But neither, nothing is written in my time folders.
I know that by modifying the solver, we can make it write the same variables that we write by executing postProcess commands, but I want to learn where in my procedure of creating new functionObjects, I am wrong.
I appreciate your help dear foamers,
regards
mkhm is offline   Reply With Quote
Old   August 22, 2018, 05:45
K
No one could help me ?
Old   March 8, 2019, 02:35
Smile OpenFOAM Post-Processing
Ali Shahanaghi
Alishaha2 is on a distinguished road
you need to add following lines to your .C - main function
Foam::timeSelector::addOptions();
#include "addRegionOption.H"
#include "addDictOption.H"
#include "setRootCase.H"
#include "createTime.H"
Foam::instantList timeDirs = Foam::timeSelector::select0(runTime, args);
#include "createNamedMesh.H"
forAll(timeDirs, timeI)
runTime.setTime(timeDirs[timeI], timeI);
Foam::Info<< "Time = " << runTime.timeName() << Foam::endl;
mesh.readUpdate();
Foam::Yourfunction(args, runTime, mesh);
Foam::Info<< Foam::endl;
Alishaha2 is offline   Reply With Quote
functionobjects, openfoam, postprocess, utility
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
