Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
The sampled data is not restricted to the defined zone in topoSetDict
Old   August 13, 2018, 17:22
Default The sampled data is not restricted to the defined zone in topoSetDict
jiaodanuma is on a distinguished road
Hi foamers
I defined a box zone in topoSetDict to restrict the sampled data in a plane. However, the sampled data is not confined to the defined box zone as illustrated in the following pictures, where fractions in the red rectangular only is the supposed part to be sampled. I have no idea how this happens... Can anyone help please? Thanks in advance!
code in topoSetDict is as follows:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    zone1;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
            box (-0.1125 -0.1125 -0.1125) (0.4125 0.1125 0.1125);
        name    zone1;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set zone1;
and code for sampled surface is listed below
sampled_surface
        type                   surfaces;
        functionObjectLibs    ("libsampling.so");
        enabled                true;
        outputControl          timeStep;
        outputInterval         5;
        surfaceFormat          raw;
        interpolationScheme    cell;
        fields
              U
              p
        surfaces
              front
                 type        plane;
                 basePoint   (-0.075 0 0);
                 normalVector            (1 0 0);
                 //interpolate           true;
                 //traingulate             false;
                 zone        zone1;
jiaodanuma is offline   Reply With Quote
Old   August 14, 2018, 08:25
Hi everyone, I find this problem only happens when sampling data at run-time. The zone woks fine when using sampleDict for post-processing. Any suggestion to improve the sampling code based in controlDict please, avoiding saving enormous data for post processing.
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 16:02
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
