Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Unable to run paraview
Old   June 27, 2018, 08:50
Default Unable to run paraview
Vaibhav
vaibhavkhare is on a distinguished road
I have OpenFoam v1712 installed in Windows 10 with docker. All thinga are running fine but when i try to open paraFoam then its shows following error:
ERROR: ParaView reader module library (PVFoamReader) does not exist
Please build the reader module before continuing:
cd $WM_PROJECT_DIR/applications/utilities/postProcessing/graphics/PVReaders
./Allwclean
./Allwmake
When i run the above command in terminal, it shows:
Using the native VTK/OpenFOAM reader instead
Created temporary 'ofuser.foam'
/opt/OpenFOAM/OpenFOAM-v1712/bin/paraFoam: line 319: paraview: command not found
[ofuser@default ~]$ cd $WM_PROJECT_DIR/applications/utilities/postProcessing/graphics/PVReaders
[ofuser@default PVReaders]$ ./Allwclean
wclean libso foamPv
wclean libso vtkPVblockMesh
wclean libso vtkPVFoam
[ofuser@default PVReaders]$ ./Allwmake
==> skip build of ParaView plugins
include directory was for paraview major version 'none'
After that, i am not able to go back into my workingDir also.
I have searched for solution but seems like it is a common problem for OpenFoam. Has anyone got the solution of the above error???
vaibhavkhare is offline   Reply With Quote
Old   July 23, 2018, 15:44
Smile
cyss38's Avatar
Cyrille Bonamy
cyss38 is on a distinguished road
On windows, the solution is in the help : https://www.openfoam.com/download/in...ry-windows.php
More precisely :
"How can I post process the results from OpenFOAM? I am unable to launch Paraview/ParaFoam from terminal?
You will need to install ParaView for Windows separately from ParaView. Create a file with the suffix ”.foam” e.g. type the command ”touch a.foam” in your case folder. Launch ParaView and browse the case folder. Open the file with suffix ”.foam” to start the post processing."
So just install paraview for windows : https://www.paraview.org/paraview-do...dows-64bit.exe
cyss38 is offline   Reply With Quote
openfoam postprocessing, parafoam, paraview
Long loading times and unable to run with 4 cores in ANSYS AIM Vestdam ANSYS 0 October 4, 2018 04:10
[OpenFOAM.org] Problems to install openfoam-2.4.0 on Ubuntu 16.04.01LTS matheusmonjon OpenFOAM Installation 3 February 25, 2017 15:46
Run in parallel slow and cannot open the mesh in Paraview qjh888 OpenFOAM Running, Solving & CFD 0 July 13, 2016 05:55
unable to run in parallel with OpenFOAM 2.2 on CentOS einatlev OpenFOAM Running, Solving & CFD 9 June 26, 2014 01:24
[OpenFOAM] run paraFoam command results in error: line 267: paraview: command not found. Asik ParaView 1 December 25, 2013 12:45
