Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Question about sampleDict
Old   June 20, 2018, 23:26
Default Question about sampleDict
Jun
mykkujinu2201 is on a distinguished road
Dear all,
I have a question about sampleDict of OpenFoam.
I am currently working on post-processing.
I need to sample field data along a line.
The problem is that I do not know about the start point and the end point of the line. The line must consist of pressure maxima on every y-z cross section along x axis.
Also, the line is not straight.
Is it possible to use sampleDict in this situation?
Or should I code on my own?
Jun
mykkujinu2201 is offline   Reply With Quote
Old   June 21, 2018, 07:06
Default The problem has been solved.
Jun
I solved the problem by sampling y-z cross sections with different x values.
After the cross section, I did post process with MATLAB.
I opened the sampled file at MATLAB and found the position to sample again.
At the last, I did sample the values at the points.
By the way, does anyone have better way?
openfoam, postprocessing, sampledict
Question on sampleDict musahossein OpenFOAM Running, Solving & CFD 8 May 8, 2013 18:48
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 11:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 14:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 16:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
