Error requesting rho file while calculating Courant field - OF 2.4.0, sonicFoam |
June 1, 2018, 11:28 |
Deep
Rep Power: 9 |
I have had to run my case in 2.4.0 instead of 5.0 because of version unavailability on this machine. The courant number is shooting up after some time and I'm trying to find out where by plotting Co field. In 2.4.0, that's done by "Co" command after reconstructPar. When I run this, I get following error: Code:
Time = 3e-08 Reading phi Calculating compressible Co Reading rho --> FOAM Warning : --> FOAM FATAL IO ERROR: cannot find file file: /path/x_latest/case/3e-08/rho at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. The description of this utility from the 2.4.0 user guide says Co is calculated based on Phi. So am a bit baffled at why this error about rho. Can anyone direct me the right way? |
courant number, openfoam 2.4.0, postprocessing, sonicfoam |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 19:13 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
