March 16, 2018, 05:57 |
Sample a volume field from mesh
Zhiyi Li
Rep Power: 11 |
Dear Foamers,
Because I need to do analysis in a specific region of my LES simulation, i need to sample a sub-field of the cylinder mesh. The sampled field (volume) is like a smaller cylinder inside the current cylinder mesh. I have checked a lot on the Internet, couldn'd find a solution. It seems that the sample function only support the set and surface sampling. Any suggestions? Thanks lot! Best Litchy |
January 16, 2019, 10:47 |
Jin Zhang
Rep Power: 8 |
Hi Litchy,
I am now running across the same problem as you. Have you solved this problem? I know that 'volRegion' can be used for cellZone, but I can only get the volume-averaged value rather than the values for each cell in cellZone. Kind regards, Jin |
field, sample, volume |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
