Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
calculation of drag force for a bubble
Old   February 11, 2018, 09:19
Default calculation of drag force for a bubble
A. Min
alimea is on a distinguished road
Hi every body
I want to calculate drag coefficient that is applied to a bubble which arises in a liquid. You know that forceCoeff code is for a boundary patch.
Thanks
alimea is offline   Reply With Quote
Old   August 30, 2019, 07:26
cyw
Yuanwei Cao
cyw is on a distinguished road
Originally Posted by alimea View Post
Hi every body
Thanks
Have you solved this problem? Thank you!
cyw is offline   Reply With Quote
Old   August 30, 2019, 13:21
A. Min
According to my searches, drag should be calculated using force balance on bubble.
regards
Old   August 30, 2019, 16:46
cyw
Yuanwei Cao
regards
Thank you for your message. Could you tell me more? Which forces are in balance?
Old   August 31, 2019, 03:34
A. Min
You can find the Terminal velocity of the bubble using the balance of all of the forces applied to it, such as gravity, buoyancy, drag ,... . Finally the drag force can be found with Terminal velocity.
Regards
bubble, drag
Regarding modified drag force formulation for application in dense flows ansubru OpenFOAM Programming & Development 15 September 14, 2014 10:04
Lift force and Drag force calculation KTJ STAR-CCM+ 3 April 29, 2014 09:38
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Airfoil Drag Force wowakai Main CFD Forum 3 October 13, 1998 20:27
