Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
vtkUnstructuredToFoam in OpenFOAM
Old   February 6, 2018, 04:54
Exclamation vtkUnstructuredToFoam in OpenFOAM
Vishwesh Ravi Shrimali
vishwesh is on a distinguished road
Hi
I have a question regarding the OpenFOAM pre-processing utility - vtkUnstructuredToFoam. Now, if I understand it correctly, this utility takes a vtk Unstructured file as input and then converts it into a Polymesh.
Now, I ran a simulation using OpenFOAM and then saved the data at a particular time step (t = 0.35) in vtm format using paraView. This vtm file had all the info, mesh, U, alpha.water, etc. Again, I opened the corresponding vtu file in ParaView and saved it in vtk format. This file had all the data: U, alpha.water, points, faces, etc.
Now if I run vtkUnstructuredToFoam utility. I only get the polymesh without the boundary conditions, U, alpha.water and other parameter. But if I check the log file:
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 3.0.x
Exec   : vtkUnstructuredToFoam data_vtk.vtk
Date   : Feb 06 2018
Time   : 14:10:26
Host   : "cgscd000ggb3t92"
PID    : 4422
Case   : /data/cfd_ext/Student_Interns_2017/vishwesh/damBreak/data
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Header   : "# vtk DataFile Version 4.0"
Title    : "vtk output"
dataType : "ASCII"
line:4 tag:DATASET
geomType : UNSTRUCTURED_GRID
line:5 tag:POINTS
Reading 4746 numbers representing 4746 coordinates.
line:1589 tag:CELLS
Reading 2268 cells or faces.
line:3859 tag:CELL_TYPES
Read 2268 cells;0 faces.
line:6129 tag:CELL_DATA
line:6130 tag:SCALARS
Reading scalar p of type float from lookup table
line:6385 tag:VECTORS
Reading vector U of type float
line:7143 tag:FIELD
dataName:FieldData
numArrays:5
Reading field alpha.water of 2268 tuples of rank 1
Reading field epsilon of 2268 tuples of rank 1
Reading field k of 2268 tuples of rank 1
Reading field nut of 2268 tuples of rank 1
Reading field p_rgh of 2268 tuples of rank 1
line:8414 tag:POINT_DATA
line:8415 tag:SCALARS
line:8945 tag:VECTORS
line:10529 tag:FIELD
dataName:FieldData
numArrays:5
Reading field alpha.water of 4746 tuples of rank 1
Reading field epsilon of 4746 tuples of rank 1
Reading field k of 4746 tuples of rank 1
Reading field nut of 4746 tuples of rank 1
Reading field p_rgh of 4746 tuples of rank 1
Read points:4746 cellShapes:2268 faces:0 lines:0
Cell fields:
Read 1 vectorField fields:
Size    Name
2268    U
Read 6 scalarField fields:
Size    Name
2268    nut
2268    alpha.water
2268    k
2268    p_rgh
2268    p
2268    epsilon
Point fields:
Size    Name
4746    U
Size    Name
4746    nut
4746    alpha.water
4746    k
4746    p_rgh
4746    p
4746    epsilon
Other fields:
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 625
    Found 4744 undefined faces in mesh; adding to default patch.
Writing mesh ...
End
Clearly the utility is able to detect the scalars and vectors present in the vtk file. Is it possible to save this data in separate files? Like a U file, an alpha.water file, etc.?
Thanks in advance for the help.
vishwesh is offline   Reply With Quote
Old   January 19, 2021, 10:05
anon
lcalian is on a distinguished road
Hi Vishwesh, sorry to respond to a long-dead post, but did you have any luck with vtkUnstructuredToFoam? I have a similar problem, I'm trying to transfer field data into OF. The only other work-around I can think of would be to write a Python or bash script to read the field data and format it correctly for my OF boundary condition file.
lcalian is offline   Reply With Quote
openfoam 3.0.x, vtk
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 04:43
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
