rhoPorousSimpleFoam log doesn't show velocity residuals. Why ? |
February 2, 2018, 10:52 |
Deep
Rep Power: 8 |
I didn't check any other solvers for similar behaviour but I was wondering what could be the reason for the log file of a rhoPorousSimpleFoam run to not have any statements related to residuals for components of velocity (Vx, Vy, Vz). A sample shown here: Code:
Time = 99.6 smoothSolver: Solving for e, Initial residual = 1.24842e-05, Final residual = 1.06802e-06, No Iterations 6 GAMG: Solving for p, Initial residual = 0.160114, Final residual = 0.0069152, No Iterations 4 time step continuity errors : sum local = 22.6147, global = 7.58542, cumulative = 670.597 pressureControl: p max 356688 pressureControl: p min -28757.3 smoothSolver: Solving for epsilon, Initial residual = 0.00352868, Final residual = 0.000271387, No Iterations 12 smoothSolver: Solving for k, Initial residual = 0.00314641, Final residual = 0.000226256, No Iterations 12 ExecutionTime = 1419.42 s ClockTime = 1421 s Time = 99.8 smoothSolver: Solving for e, Initial residual = 1.19621e-05, Final residual = 1.02603e-06, No Iterations 6 GAMG: Solving for p, Initial residual = 0.176217, Final residual = 0.00653495, No Iterations 4 time step continuity errors : sum local = 20.0158, global = 6.15405, cumulative = 676.751 pressureControl: p max 356755 pressureControl: p min -24329 smoothSolver: Solving for epsilon, Initial residual = 0.0781304, Final residual = 0.00139665, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.12155, Final residual = 0.00112023, No Iterations 2 ExecutionTime = 1422.04 s ClockTime = 1424 s |
February 23, 2022, 03:53 |
I also have the same problem with v2012. Anyone else is having the same issue?
Mach and Velocity Magnitude Plots show different values | Sabomb | FLUENT | 0 | October 29, 2016 13:57 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
velocity residuals is above 0.01. | hotboy | FLUENT | 2 | December 2, 2014 14:12 |
[swak4Foam] Creating log. velocity profile with groovyBC | krsp | OpenFOAM Community Contributions | 2 | March 15, 2012 06:37 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
