November 7, 2017, 03:06 |
Unknown function type pressureTools
Rep Power: 9 |
I'm trying to use the pressureTools function in order to compute the pressure coefficient around a wing. However I have the following error : Code:
Starting time loop --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 671 Caught FatalError --> FOAM FATAL ERROR: Unknown function type pressureTools Valid functions are : 15 ( abort coded patchProbes probes psiReactionThermoMoleFractions removeRegisteredObject residuals rhoReactionThermoMoleFractions setTimeStep sets surfaces systemCall timeActivatedFileUpdate writeDictionary writeObjects ) Code:
functions { pressureTools1 { type pressureTools; functionObjectLibs ("libutilityFunctionObjects.so"); enabled yes; region defaultRegion; calcTotal no; calcCoeff yes; timeStart 10; timeEnd 10; writeControl outputTime; writeInterval 1; rhoInf 1.17663; pInf 101325; UInf (231.91 0 0); } } Thank you Dorian |
November 7, 2017, 04:49 |
pressureTools were renamed in pressure (in version 4.x). Now the function resides in libfieldFunctionObjects library. So, answering your question, the reason for the message is "you are trying to use old settings for new version of OpenFOAM". |
November 8, 2017, 04:33 |
Rep Power: 9 |
Thank you very much, it works perfectly !
Dorian |
January 4, 2018, 14:34 |
Jason G.
Rep Power: 17 |
I am currently working on making the switch from OF3.0 to 5.0, and have also hit my first road block with the change from pressureTools.
My current OF3.0 code exports the areaAverage of the static pressure field on a specified patch: Code:
#include "../0/initialConditions" pressure_tools1 { type pressureTools; functionObjectLibs ("libutilityFunctionObjects.so"); enabled yes; outputControl outputTime;//timeStep;// rhoName rhoInf; rhoInf $density;// Value of the density(sslug/in^3) pstatic = lbf/in^2 pRef $pressure; calcTotal no; //yes for total, need to change reloadTotalP and inlet_avg_tot_p calcCoeff no; } reloadPcalc { type readFields; functionObjectLibs ("libfieldFunctionObjects.so"); //region defaultRegion; enabled yes; timeStart 10; timeEnd 10000; outputInterval 10; // 5000; fields ( // "total(p)" "static(p)" ); } inlet_1_ps { type faceSource; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; timeStart 10; timeEnd 10000; outputInterval 10; // 5000; log true; valueOutput false; source patch; sourceName inlet_1; operation areaAverage; //operation weightedAverage; //weightField phi; fields ( //"total(p)" "static(p)" ); } Code:
#include "../0/initialConditions" pressure_tools1 { type pressure; //pressureTools; renamed "pressure" in OF5.0 functionObjectLibs ("libfieldFunctionObjects.so"); //("libutilityFunctionObjects.so"); enabled yes; //outputControl outputTime;//timeStep;// writeControl outputTime; rhoName rhoInf; rhoInf $density;// Value of the density(sslug/in^3) pstatic = lbf/in^2 pRef $pressure; calcTotal no; //yes for total, need to change reloadTotalP and inlet_avg_tot_p calcCoeff no; } reloadPcalc { type readFields; functionObjectLibs ("libfieldFunctionObjects.so"); //region defaultRegion; enabled yes; timeStart 10; timeEnd 10000; writeControl writeTime; writeInterval 10; outputInterval 10; // 5000; fields ( // "total(p)" "static(p)" ); } inlet_1_ps { type surfaceFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType patch; name inlet_1; operation areaAverage; fields ( // "total(p)" "static(p)" ); } |
January 4, 2018, 16:02 |
surfaceFormat is not required if you do not write fields. See the code: Code:
if (writeFields_) { const word surfaceFormat(dict.lookup("surfaceFormat")); surfaceWriterPtr_.reset ( surfaceWriter::New ( surfaceFormat, dict.subOrEmptyDict("formatOptions"). subOrEmptyDict(surfaceFormat) ).ptr() ); } |
January 5, 2018, 15:11 |
Jason G.
Rep Power: 17 |
Thanks!
In order to get my static pressure as a product of the density and kinematic pressure, I had to define "rho" as follows: Code:
#include "../0/initialConditions" pressure_tools1 { type pressure; //pressureTools; renamed "pressure" in OF5.0 functionObjectLibs ("libfieldFunctionObjects.so"); //("libutilityFunctionObjects.so"); writeControl outputTime; rho rhoInf; rhoInf $density;// Value of the density(sslug/in^3) pstatic = lbf/in^2 pRef $pressure; calcTotal no; //yes for total, need to change reloadTotalP and inlet_avg_tot_p calcCoeff no; } |
January 5, 2018, 15:35 |
Jason G.
Rep Power: 17 |
For the majority of my simulations, I will initialize fields with the potentialFoam solver. I just realized that my boundary conditions do not appear to be working correctly in OF 5.0 when using potentialFoam. The only thing I can think that might be throwing it off is my inlet velocity BC, any suggestions?
U: Code:
#include "initialConditions" dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { "inlet.*" { type surfaceNormalFixedValue; refValue uniform $velMag; value uniform (0 0 0); /* type inletOutlet; inletValue $flowVelocity; value $flowVelocity; */ } "outlet.*" { // type zeroGradient; type inletOutlet; inletValue $internalField; value $internalField; } "boundary.*" { type fixedValue; value $internalField; } "symmetry.*" { type symmetry; } } Code:
#include "initialConditions" //pressure_inlet_p #calc "$p_inlet / $density"; dimensions [0 2 -2 0 0 0 0]; internalField uniform $pressure; boundaryField { "inlet.*" { type outletInlet; outletValue $internalField; value $internalField; } "outlet.*" { type fixedValue; value $internalField; } "symmetry.*" { type symmetry; } "boundary.*" { type zeroGradient; } } Code:
#include "initialConditions" dimensions [0 0 -1 0 0 0 0]; internalField uniform $turbulentOmega; omegaF fixedValue; //omegaWallFunction; boundaryField { "inlet.*" { /* type fixedValue; value uniform $omega_inlet; */ type zeroGradient; } "outlet.*" { type zeroGradient; // type inletOutlet; // inletValue $internalField; // value $internalField; } "boundary.*" { type $omegaF; value uniform 1e-10; } "symmetry.*" { type symmetry; } } Code:
dimensions [0 2 -1 0 0 0 0]; internalField uniform 1e-10; nutModel fixedValue; //nutLowReWallFunction; //nutUWallFunction //nutUSpaldingWallFunction //nutLowReWallFunction boundaryField { "inlet.*" { type zeroGradient; } "outlet_.*" { type zeroGradient; } "boundary.*" { type $nutModel; value uniform 1e-10; } "symmetry.*" { type symmetry; } } Code:
#include "initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $turbulentKE; kWallF fixedValue; //kqRWallFunction; boundaryField { "inlet.*" { /* type fixedValue; value uniform $ke_inlet; */ type zeroGradient; } "outlet.*" { type zeroGradient; } "boundary.*" { type $kWallF; value uniform 1e-10; } "symmetry.*" { type symmetry; } } Code:
#include "initialConditions" dimensions [ 0 2 -3 0 0 0 0 ]; internalField uniform $turbulentDissipation; eWallF fixedValue; //epsilonWallFunction; boundaryField { "inlet.*" { /* type fixedValue; value uniform $dissipation_inlet; */ type zeroGradient; } "outlet.*" { type zeroGradient; } "boundary.*" { type $eWallF; value uniform 1e-10; } "symmetry.*" { type symmetry; } } |
January 5, 2018, 17:40 |
1. rho value should be a name of density field or rhoInf (in this case rho is set uniformly to the value of rhoInf). So, your configuration is OK. 2. Was not able to find inclusion of fvIOoptionList.H in version 3.0.x (https://github.com/OpenFOAM/OpenFOAM...otentialFoam.C). So could you elaborate concerning "do not appear to be working correctly in OF 5.0"? |
January 5, 2018, 17:49 |
#9 | |
Jason G.
Rep Power: 17 |
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2011-2015 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Application potentialFoam Description Potential flow solver which solves for the velocity potential from which the flux-field is obtained and velocity field by reconstructing the flux. This application is particularly useful to generate starting fields for Navier-Stokes codes. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "pisoControl.H" #include "fvIOoptionList.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { argList::addOption ( "pName", "pName", "Name of the pressure field" ); argList::addBoolOption ( "initialiseUBCs", "Initialise U boundary conditions" ); argList::addBoolOption ( "writePhi", "Write the velocity potential field" ); argList::addBoolOption ( "writep", "Calculate and write the pressure field" ); argList::addBoolOption ( "withFunctionObjects", "execute functionObjects" ); #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" pisoControl potentialFlow(mesh, "potentialFlow"); #include "createFields.H" #include "createMRF.H" #include "createFvOptions.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< nl << "Calculating potential flow" << endl; // Since solver contains no time loop it would never execute // function objects so do it ourselves runTime.functionObjects().start(); MRF.makeRelative(phi); adjustPhi(phi, U, p); // Non-orthogonal velocity potential corrector loop while (potentialFlow.correctNonOrthogonal()) { fvScalarMatrix PhiEqn ( fvm::laplacian(dimensionedScalar("1", dimless, 1), Phi) == fvc::div(phi) ); PhiEqn.setReference(PhiRefCell, PhiRefValue); PhiEqn.solve(); if (potentialFlow.finalNonOrthogonalIter()) { phi -= PhiEqn.flux(); } } MRF.makeAbsolute(phi); Info<< "Continuity error = " << mag(fvc::div(phi))().weightedAverage(mesh.V()).value() << endl; U = fvc::reconstruct(phi); U.correctBoundaryConditions(); Info<< "Interpolated velocity error = " << (sqrt(sum(sqr((fvc::interpolate(U) & mesh.Sf()) - phi))) /sum(mesh.magSf())).value() << endl; // Write U and phi U.write(); phi.write(); // Optionally write Phi if (args.optionFound("writePhi")) { Phi.write(); } // Calculate the pressure field if (args.optionFound("writep")) { Info<< nl << "Calculating approximate pressure field" << endl; label pRefCell = 0; scalar pRefValue = 0.0; setRefCell ( p, potentialFlow.dict(), pRefCell, pRefValue ); // Calculate the flow-direction filter tensor volScalarField magSqrU(magSqr(U)); volSymmTensorField F(sqr(U)/(magSqrU + SMALL*average(magSqrU))); // Calculate the divergence of the flow-direction filtered div(U*U) // Filtering with the flow-direction generates a more reasonable // pressure distribution in regions of high velocity gradient in the // direction of the flow volScalarField divDivUU ( fvc::div ( F & fvc::div(phi, U), "div(div(phi,U))" ) ); // Solve a Poisson equation for the approximate pressure while (potentialFlow.correctNonOrthogonal()) { fvScalarMatrix pEqn ( fvm::laplacian(p) + divDivUU ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); } p.write(); } runTime.functionObjects().end(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; Info<< "End\n" << endl; return 0; } Next, I will likely try the standard uniform fixedRate inlet BC for the velocity. |
January 5, 2018, 18:43 |
#10 |
Concerning fvOptions, finally it was removed: https://github.com/OpenFOAM/OpenFOAM...b3960a2ae08574 https://bugs.openfoam.org/view.php?id=1964 In fact, I do not see anything special in your boundary conditions (i.e. something that can lead to big difference in results). So I would suppose, it is, for example, convergence criterion, who makes the difference. Yet, without additional information it is difficult to say. |
January 8, 2018, 09:47 |
#11 |
Jason G.
Rep Power: 17 |
I think you are correct. I have attempted to run with a non derived BC at the inlet, and I am still getting incorrect results. Attached are images of the static pressure field on my inlet patch. The more uniform image is from my solution that was run without first running potentialFoam, while the more discontinuous image is from my solution after running potentialFoam first.
fvSchemes: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; // grad(p) Gauss linear; //commented out on 8/6/2015 grad(U) Gauss linear; } ///* divSchemes { default none; div(phi,U) bounded Gauss linearUpwindV grad(U); div(div(phi,U)) Gauss linear; //added on 8/6/2015 div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,R) bounded Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; //added for OF3.0 on 5/5/2017 div(phi,omega) bounded Gauss upwind; } laplacianSchemes { default Gauss linear corrected; //Gauss linear limited 0.5; laplacian(nuEff,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; //limited 0.5; } fluxRequired { default no; p ; Phi; } wallDist { method meshWave; } fvSolution: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-06; relTol 0.05; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; nPreSweeps 0; //course book suggests =0 if converging rapidly, pre 1/18/2016 has been =0, try 2 nPostSweeps 2; } Phi { $p; //added on 8/6/2015 } "(U|k|epsilon|R|nuTilda|omega)" { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-05; relTol 0.1; /* solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; */ } } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-4; U 1e-4; "(k|epsilon|omega)" 1e-4; } } potentialFlow { nNonOrthogonalCorrectors 15; } relaxationFactors //values <1 = under relaxation = more solution smoothing per iteration = more iterations to converge but may help stability. { fields { p 0.4; } equations { "(U|k|epsilon|omega)" 0.7; } } cache { grad(U); } |
January 8, 2018, 10:19 |
#12 |
Could you add output of checkMesh and simpleFoam execution log-file (or a fragment of several iterations, if whole file is too large)? |
January 8, 2018, 10:37 |
#13 |
Jason G.
Rep Power: 17 |
With this particular geometry I routinely have bad orthogonality in areas of my flow domain that I do not believe greatly impact my overall result. This particular mesh did achieve what I understand to be reasonable residuals. I am meshing with Ansys Workbench, so it is often difficult to achieve a mesh that doesn't trip errors via checkMesh.
checkMesh: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-197d9d3bf20a Exec : checkMesh Date : Jan 08 2018 Time : 09:20:50 Host : "TASNC-JASONG" PID : 476 I/O : uncollated Case : /mnt/d/swap/OF5/fr_015_nopotential nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 634982 internal points: 588346 faces: 4185842 internal faces: 4093322 cells: 1841411 faces per cell: 4.496097829 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 913520 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 927891 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet_1 618 552 ok (non-closed singly connected) outlet_1 550 485 ok (non-closed singly connected) boundary 91352 45681 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.8299974967 -3.337989933 2.248993217) (4.069987725 -1.782494624 6.698979796) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (2.743163375e-16 1.953206601e-17 -1.082883888e-16) OK. Max cell openness = 3.77981887e-15 OK. Max aspect ratio = 75.0854888 OK. Minimum face area = 8.506288038e-07. Maximum face area = 0.001358804478. Face area magnitudes OK. Min volume = 9.482619624e-10. Max volume = 1.642345168e-05. Total volume = 2.673134835. Cell volumes OK. Mesh non-orthogonality Max: 84.22602788 average: 22.41349842 *Number of severely non-orthogonal (> 70 degrees) faces: 2494. Non-orthogonality check OK. <<Writing 2494 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 4.515003866, 103 highly skew faces detected which may impair the quality of the results <<Writing 103 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-197d9d3bf20a Exec : simpleFoam -parallel Date : Jan 05 2018 Time : 14:21:29 Host : "TASNC-JASONG" PID : 1572 I/O : uncollated Case : /mnt/d/swap/OF5/fr_015_nopotential nProcs : 20 Slaves : 19 ( "TASNC-JASONG.1573" "TASNC-JASONG.1574" "TASNC-JASONG.1575" "TASNC-JASONG.1576" "TASNC-JASONG.1577" "TASNC-JASONG.1578" "TASNC-JASONG.1579" "TASNC-JASONG.1580" "TASNC-JASONG.1581" "TASNC-JASONG.1582" "TASNC-JASONG.1583" "TASNC-JASONG.1584" "TASNC-JASONG.1585" "TASNC-JASONG.1586" "TASNC-JASONG.1587" "TASNC-JASONG.1588" "TASNC-JASONG.1589" "TASNC-JASONG.1590" "TASNC-JASONG.1591" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.0001 field U tolerance 0.0001 field "(k|epsilon|omega)" tolerance 0.0001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.5555555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No finite volume options present Starting time loop --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry flowVelocity is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry velMag is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry pressure is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry turbulentKE is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry ke_inlet is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry turbulentOmega is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry omega_inlet is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry turbulentDissipation is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry dissipation_inlet is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry kinematicvis is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry density is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry pressure_inlet_p is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry RAS_MODEL is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry turb_on_off is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_nopotential/system/controlDict" from line 18 to line 63 Entry RAS is not a dictionary surfaceFieldValue inlet_1_ps: total faces = 618 total area = 0.1271218506 Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.02319208891, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.06173220055, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.06357360331, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.04194346275, No Iterations 10 time step continuity errors : sum local = 0.6021147278, global = -0.003277611953, cumulative = -0.003277611953 smoothSolver: Solving for omega, Initial residual = 1, Final residual = 0.0724688168, No Iterations 2 bounding omega, min: -394.3638772 max: 82363.76713 average: 74832.55168 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.08488456301, No Iterations 2 bounding k, min: -1611.244139 max: 158173.6833 average: 141307.5341 ExecutionTime = 1.44 s ClockTime = 1 s Code:
Time = 2999 smoothSolver: Solving for Ux, Initial residual = 7.301673623e-08, Final residual = 7.301673623e-08, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 2.806229147e-07, Final residual = 2.806229147e-07, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 1.080360349e-07, Final residual = 1.080360349e-07, No Iterations 0 GAMG: Solving for p, Initial residual = 8.440299749e-07, Final residual = 8.440299749e-07, No Iterations 0 time step continuity errors : sum local = 0.0005352652103, global = 1.331025375e-07, cumulative = 0.7651170161 smoothSolver: Solving for omega, Initial residual = 9.704782841e-06, Final residual = 9.704782841e-06, No Iterations 0 smoothSolver: Solving for k, Initial residual = 0.001131603768, Final residual = 8.997397795e-05, No Iterations 4 ExecutionTime = 1821.81 s ClockTime = 1871 s Time = 3000 smoothSolver: Solving for Ux, Initial residual = 7.276841407e-08, Final residual = 7.276841407e-08, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 2.797101669e-07, Final residual = 2.797101669e-07, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 1.075325789e-07, Final residual = 1.075325789e-07, No Iterations 0 GAMG: Solving for p, Initial residual = 9.133011199e-07, Final residual = 9.133011199e-07, No Iterations 0 time step continuity errors : sum local = 0.0005791954494, global = 1.408492347e-07, cumulative = 0.7651171569 smoothSolver: Solving for omega, Initial residual = 9.705228485e-06, Final residual = 9.705228485e-06, No Iterations 0 smoothSolver: Solving for k, Initial residual = 0.001131631611, Final residual = 8.997609092e-05, No Iterations 4 ExecutionTime = 1822.86 s ClockTime = 1872 s functionObjects::pressure pressure_tools1 writing field: static(p) surfaceFieldValue inlet_1_ps write: areaAverage(inlet_1) of static(p) = 91.96423347 End Finalising parallel run |
January 8, 2018, 18:03 |
#14 |
Jason G.
Rep Power: 17 |
I just went back and re-ran with and without potentialFoam on OpenFOAM 3.0, and the results are both in close agreement.
January 9, 2018, 08:31 |
#15 |
Except from log-file you have posted finishes at 3000 iterations and it seems there is no convergence yet (otherwise execution is ended with "SIMPLE converged in ... iterations"). Though residuals for U, p, and omega fields looks fine, k residuals are high. Btw to which case posted log-file corresponds: potentialFoam initialised or not? As a side note: your discretisation schemes/solver settings are not quite correct for the mesh you have. I would suggest: - Use leastSquares for gradient. - Also you can limit non-orthogonal correction for laplacian and interpolation. - Use at least 2 non-orthogonal correctors in SIMPLE dictionary. Yet, according to log your case converges without those additions. |
January 9, 2018, 09:59 |
#16 |
Jason G.
Rep Power: 17 |
For these types of simulations I have been focused on expediency of result while maintaining a "reasonable" solution accuracy. For this model, I find that the level of convergence I typically get by 3000 iterations is sufficient.
The log file posted was the model without running potentialFoam. The log file after changing to leastSquares and setting nNonOrthogonalCorrectors to 2 is shown below: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-197d9d3bf20a Exec : simpleFoam -parallel Date : Jan 09 2018 Time : 08:39:06 Host : "TASNC-JASONG" PID : 1553 I/O : uncollated Case : /mnt/d/swap/OF5/fr_015_solvertest nProcs : 20 Slaves : 19 ( "TASNC-JASONG.1554" "TASNC-JASONG.1555" "TASNC-JASONG.1556" "TASNC-JASONG.1557" "TASNC-JASONG.1558" "TASNC-JASONG.1559" "TASNC-JASONG.1560" "TASNC-JASONG.1561" "TASNC-JASONG.1562" "TASNC-JASONG.1563" "TASNC-JASONG.1564" "TASNC-JASONG.1565" "TASNC-JASONG.1566" "TASNC-JASONG.1567" "TASNC-JASONG.1568" "TASNC-JASONG.1569" "TASNC-JASONG.1570" "TASNC-JASONG.1571" "TASNC-JASONG.1572" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.0001 field U tolerance 0.0001 field "(k|epsilon|omega)" tolerance 0.0001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.5555555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No finite volume options present Starting time loop --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry flowVelocity is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry velMag is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry pressure is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry turbulentKE is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry ke_inlet is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry turbulentOmega is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry omega_inlet is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry turbulentDissipation is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry dissipation_inlet is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry kinematicvis is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry density is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry pressure_inlet_p is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry RAS_MODEL is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry turb_on_off is not a dictionary --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 611 Reading "/mnt/d/swap/OF5/fr_015_solvertest/system/controlDict" from line 18 to line 63 Entry RAS is not a dictionary surfaceFieldValue inlet_1_ps: total faces = 618 total area = 0.1271218506 Time = 1 smoothSolver: Solving for Ux, Initial residual = 0.1256681508, Final residual = 0.009642063592, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.1548427967, Final residual = 0.008559163645, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.1385402292, Final residual = 0.008226416344, No Iterations 2 GAMG: Solving for p, Initial residual = 0.9589918949, Final residual = 0.02637324409, No Iterations 4 GAMG: Solving for p, Initial residual = 0.1931855671, Final residual = 0.003703265407, No Iterations 2 GAMG: Solving for p, Initial residual = 0.02968140513, Final residual = 0.0009574056296, No Iterations 2 time step continuity errors : sum local = 0.1295320028, global = 0.008506271131, cumulative = 0.008506271131 smoothSolver: Solving for omega, Initial residual = 1, Final residual = 0.07218038063, No Iterations 2 bounding omega, min: -602.143029 max: 119954.4881 average: 74424.48168 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.08486662264, No Iterations 2 bounding k, min: -1943.408845 max: 182529.4365 average: 140734.7014 ExecutionTime = 1.64 s ClockTime = 2 s Time = 310 smoothSolver: Solving for Ux, Initial residual = 0.0003381633688, Final residual = 2.66547049e-05, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.0007423103212, Final residual = 5.842461714e-05, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.000679501686, Final residual = 5.296519615e-05, No Iterations 4 GAMG: Solving for p, Initial residual = 0.001335932479, Final residual = 2.234475842e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0002037008352, Final residual = 8.973023203e-06, No Iterations 2 GAMG: Solving for p, Initial residual = 4.489984976e-05, Final residual = 1.758124958e-06, No Iterations 4 time step continuity errors : sum local = 0.0003066761254, global = 1.384122755e-05, cumulative = 0.003400169057 smoothSolver: Solving for omega, Initial residual = 0.000901147314, Final residual = 7.201171981e-05, No Iterations 4 smoothSolver: Solving for k, Initial residual = 0.001388056077, Final residual = 0.000111335892, No Iterations 4 bounding k, min: -0.009181106753 max: 429020.3708 average: 1348.863558 ExecutionTime = 253.39 s ClockTime = 259 s functionObjects::pressure pressure_tools1 writing field: static(p) surfaceFieldValue inlet_1_ps write: areaAverage(inlet_1) of static(p) = 16.17761426 I find it puzzling that my simulation works fine with or without potentialFoam running first in OF3.0 and fine without potentialFoam in OF5.0, but running potentialFoam in OF5.0 seems to create problems. Any thoughts on if a change in potentialFoam occurred that makes it more sensitive to orthogonality and skewness? |
January 9, 2018, 10:16 |
#17 |
Jason G.
Rep Power: 17 |
I just experimented with switching from the outletInlet pressure BC to zeroGradient, as shown below:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "initialConditions" //pressure_inlet_p #calc "$p_inlet / $density"; dimensions [0 2 -2 0 0 0 0]; internalField uniform $pressure; boundaryField { "inlet.*" { /* type outletInlet; outletValue $internalField; value $internalField; */ type zeroGradient; } "outlet.*" { type fixedValue; value $internalField; } "symmetry.*" { type symmetry; } "boundary.*" { type zeroGradient; } } // ************************************************************************* // This change seems to have resolved the discontinuous pressure field at the inlet. Something about using the outletInlet BC is causing my issues with potentialFoam in OF 5.0. I suppose I could stop using potentialFoam going forward, but I was under the impression it was a good practice to run this first in my simulations to initialize the problem. |
January 9, 2018, 17:10 |
#18 |
The difference between outletInlet BC in 3.0.x and 5.x is in the criterion for switch between Neumann and Dirichlet behaviour. In 5.x it uses phi >= 0, in 3.0.x it is phi > 0. potentialFoam implementation does not change much between these versions.
Maybe this inclusion of phi == 0 can provoke instability in your case. |
January 9, 2018, 18:04 |
#19 |
Jason G.
Rep Power: 17 |
I think for now, I will just stop using potentialFoam when using the outletInlet or inletOutlet BCs.
Where do you advise looking for more information on output controls for pressure tools and surfaceFieldValue? Previously, my code for reading the static(p) field would output at a set interval that was independent of the solution write time. (Ex: start output of areaAverage for field static(p) on outlet_1 patch at 20 iterations every 20 iterations thereafter.) Currently, I am only able to get it to write out at the same interval as the main output control in controlDict. Your help has been much appreciated. Code:
#include "../0/initialConditions" pressure_tools1 { type pressure; //pressureTools; renamed "pressure" in OF5.0 functionObjectLibs ("libfieldFunctionObjects.so"); //("libutilityFunctionObjects.so"); writeControl outputTime; rho rhoInf; rhoInf $density;// Value of the density(sslug/in^3) pstatic = lbf/in^2 pRef $pressure; calcTotal no; //yes for total, need to change reloadTotalP and inlet_avg_tot_p calcCoeff no; } reloadPcalc { type readFields; functionObjectLibs ("libfieldFunctionObjects.so"); //region defaultRegion; enabled yes; timeStart 20; timeEnd 10000; outputInterval 20; fields ( // "total(p)" "static(p)" ); } outlet_avg_p { type surfaceFieldValue; libs ("libfieldFunctionObjects.so"); enabled true; log true; valueOutput false; timeStart 20; timeEnd 10000; outputInterval 20; writeFields off; regionType patch; name outlet_1; surfaceFormat none; operation areaAverage; fields ( // "total(p)" "static(p)" ); } |
January 10, 2018, 09:12 |
#20 |
Jason G.
Rep Power: 17 |
In case anyone else ever looks at this, here is what I ended up with for getting the average static pressure across my outlet patch every 10 time steps (starting after the first 20).
#include "../0/initialConditions" pressure_tools1 { type pressure; //pressureTools; renamed "pressure" in OF5.0 functionObjectLibs ("libfieldFunctionObjects.so"); //("libutilityFunctionObjects.so"); writeControl outputTime; rho rhoInf; rhoInf $density;// Value of the density(sslug/in^3) pstatic = lbf/in^2 pRef $pressure; calcTotal no; //yes for total, need to change reloadTotalP and inlet_avg_tot_p calcCoeff no; } reloadPcalc { type readFields; functionObjectLibs ("libfieldFunctionObjects.so"); enabled yes; fields ( // "total(p)" "static(p)" ); } outlet_avg_p { type surfaceFieldValue; libs ("libfieldFunctionObjects.so"); enabled true; log true; valueOutput false; timeStart 20; writeControl timeStep; writeInterval 10; writeFields off; regionType patch; name outlet_1; surfaceFormat none; operation areaAverage; fields ( // "total(p)" "static(p)" ); } |
activeBaffleVelocity boundary condition ? | om3ro | OpenFOAM Programming & Development | 10 | November 17, 2020 00:26 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 19:34 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
