Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Unknown function type pressureTools
Like Tree3Likes
Old   January 10, 2018, 16:06
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Sorry for late reply, yet possible options are described in $FOAM_SRC/OpenFOAM/db/functionObjects/functionObject/functionObject.H:
    Time controls:
    \table
        Option            | Description
        timeStep          | Execute/write every 'Interval' time-steps
        writeTime         | Execute/write every 'Interval' output times
        adjustableRunTime | Execute/write every 'Interval' run time period
        runTime           | Execute/write every 'Interval' run time period
        clockTime         | Execute/write every 'Interval' clock time period
        cpuTime           | Execute/write every 'Interval' CPU time period
        none              | Execute/write every time-step
    \endtable
JasonG likes this.
alexeym is offline   Reply With Quote
Old   May 25, 2021, 04:54
Default Entry 'type' not found in dictionary "IOstream.functions.pressure"
  #22
AlxB is on a distinguished road
I try to use the 'pressure' function described here:
https://www.openfoam.com/documentati...-pressure.html
and used in the $FOAM_TUTORIALS/incompressible/pisoFoam/RAS/cavity
https://develop.openfoam.com/develop...oam/RAS/cavity
Unfortunately I can't move on as I get the following error:
[0] --> FOAM FATAL IO ERROR: (openfoam-2012)
[0] Entry 'type' not found in dictionary "/home/.../OpenFOAM/.../run/case/system/controlDict.functions.pressure"
Here is the pressure file:
pressure1
    // Mandatory entries
    type            pressure;
    libs            (fieldFunctionObjects);
    mode            static;
Please may I have your comments about what could be wrong ?
Thank you
AlxB is offline   Reply With Quote
Old   May 25, 2021, 04:59
Alexey Matveichev
@AlxB
It would be easier to diagnose the problem if you post controlDict also.
Now it looks like you have forgotten semicolon somewhere (to type key is eaten by parser).
Old   May 25, 2021, 10:24
thanks alexeym,
you were right. my mistake was in the controlDict.
activeBaffleVelocity boundary condition ? om3ro OpenFOAM Programming & Development 10 November 17, 2020 00:26
Inlet patch problems martyn88 OpenFOAM Running, Solving & CFD 6 April 21, 2017 19:34
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
