Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
weightedAreaAverage for sampledSurface
Old   October 25, 2017, 04:42
Default weightedAreaAverage for sampledSurface
Flou is on a distinguished road
Hi !
I'm modelling a two-phase flow and I want to compute the velocity field x component average over a specified surface (sampledSurface) but keeping only the liquid part for the calculation (alpha.water = 1)
My problem is when I try to run the operation weightedAreaAverage on a sampledSurface region type I get the error :
--> FOAM FATAL IO ERROR:
Cannot use weightField for sampledSurface
My code is working well when the operation is areaAverage (so when the weightedfield is not taken into account).
Here is my function
Thanks by advance
Flora
File Type: txt cfd_post.txt (836 Bytes, 52 views)
Flou is offline   Reply With Quote
Old   August 27, 2018, 12:26
Default Solution???
Athanasios Niotis
thanosniotis is on a distinguished road
Hello! Did you find solution for this??
thanosniotis is offline   Reply With Quote
cutting plane, sampledsurface, surfacefieldvalue, weighted average
