Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallGradU
Old   September 18, 2017, 17:18
Default wallGradU
Alejandro
ancolli is on a distinguished road
In the new openfoam 5 wallGradU has been superseded by the postProcess utility:
postProcess -func 'grad(U)'
but is technically the same?
wallGradU was not calculating the grad(U) normal to the surface?
wallGradU.boundaryField()[patchi] =
-U.boundaryField()[patchi].snGrad();
How can i use the new postProcess -func 'grad(U)' to get information normal to the surface?
ancolli is offline   Reply With Quote
Old   September 19, 2017, 16:47
Alejandro
someone can explain how to use postProcess -func 'grad(U)' and get results at the wall normal surface?
I am just obtaining a tensor instead a vector for the wall. I would like to recover results as wallGradU.
Thanks
Old   September 18, 2018, 13:26
sibo
sibo is on a distinguished road
Hi Colli,
I'm wondering did you find the solution? I am facing the same problem!
Thanks a lot!
sibo is offline   Reply With Quote
Old   September 18, 2018, 13:40
Alejandro
They removed the functionality, Maybe the wallShearStress post-process functionalitty will be useful for you.
I was using wallGradU in order to modify it for mass flux at the wall. Finally, I modified wallHeatFlux in order to obtain what i wanted.
Regards
Old   September 18, 2018, 13:41
sibo
Thanks for your help!
wallGradU components amin66 OpenFOAM Post-Processing 9 March 25, 2016 21:09
wallGradU at runtime kkpal OpenFOAM Post-Processing 6 June 12, 2015 20:56
getting (0 0 0) wallGradU value when i m probing wallGradU at some points suryawanshi_nitin OpenFOAM 1 December 9, 2013 12:36
wallShearStress VS wallGradU bigrock OpenFOAM Post-Processing 0 July 2, 2013 06:54
write wallGradU to one file sven OpenFOAM 1 March 19, 2011 19:58
