Rep Power: 12 ![]() |
Hello everyone. After completing my run, I obtain temperature field from a slice and I want to make a new run using the temperature field on this slice as setting it internalField to the 2nd new run. I got temperature field of a slice as text file and now, I want to read the text file and set it as internalField. How can I do this easily? Is it meaningful to use swak4Foam or pyFoam for this problem?
pyfoam, swak4foam |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
