Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
calculate drag coefficient for body moving in waves
Old   February 13, 2017, 07:00
Default calculate drag coefficient for body moving in waves
mo_na's Avatar
Mona
mo_na is on a distinguished road
Dear all,
I am trying to calculate the drag coefficient for a body, that is doing a pitch motion in regular waves. (I attached a sketch to give you an idea of the setup.)
Drag coefficient: cd=2*Fd/(rho*U*|U|*A)
Fd: Drag force, calculated with forces function
A: reference area
rho: density
I figured that I can't use the forceCoeffs function, because U is not the free stream velocity in this case, but the relative velocity between the body and the fluid particles.
So the velocity I need here is U=u(t)-v(t), where u(t) is the flow velocity in drag direction (x) and v(t) the velocity of the body, also in x-direction. (Please correct me if I am wrong here)
Now I am wondering if any of you have some advice how to obtain those two values.
1)u(t)
This value varies throughout the flow filed around the body, so should I set several probes and then take an average value or try to pick a characteristic point?
2)v(t)
I am already outputting the angular velocity omega of the body. With v=omega*radius I will obtain the tangential velocity. But how can I obtain the x-component from that?
My plan is to calculate cd(t) in postprocessing with all these above values.
Any suggestions on how to do this are very appreciated!
Cheers,
Mona
mo_na is offline   Reply With Quote
Old   May 20, 2017, 03:56
raju ram bhakar
bhakar.raju98 is on a distinguished road
Hello Mona,
I am visualising the motion of DTC Hull in FoamExtend using groovyBC and InterIbFoam.
But I'm not able to visualise the flow around the hull geometry.
Basically I don't know how to post process the available data and generate animations.
When I open paraView using paraFoam there is region named as hull but when I use apply button there is no hull geometry of hull.
How should I proceed with it please give some suggestion
Thankyou.
bhakar.raju98 is offline   Reply With Quote
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 01:49
how to calculate drag force coefficient of cylinder in oscillating flow vhcongtltd FLUENT 10 September 25, 2014 05:59
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
how to calculate cd -- drag coefficient?????? vijesh joshi CFX 6 April 7, 2006 00:35
