Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Problems with postprocessing folder
Old   January 8, 2017, 01:15
Unhappy Problems with postprocessing folder
Óscar
Oscardcb is on a distinguished road
good morning everyone!,
I am trying to run a postprocesing folder which apparently should automatically run as teacher said, due to is included in the script. The thing is that it is not running, I was said in the lesson that if it does not run, we can use in the terminal: sample
Thas is what I did, and the terminal says:
sample has been superceded by the postProcess utility:
postProcess -func sample
To re-use existing 'sampleDict' files simply add the following entries:
type sets;
libs ("libsampling.so");
and run
postProcess -func sampleDict
Well, it seems easy but, to be honest I have trid everything and it doesnt work... I dont know what and more important where to do it. am I supposed to change sampleDict file?,or in the terminal?
I didnt find anything similar over here...
I do appreciate any help in advance
Regards
Oscardcb is offline   Reply With Quote
Old   February 1, 2017, 09:04
Michael Hoss
Knusper is on a distinguished road
It's already some weeks old, but maybe still helps you..
Does it make a difference if you include
at the bottom of your controlDict?
Also, have you tried just typing "sample" instead of "postProcess -func sample"?
Knusper is offline   Reply With Quote
Old   February 1, 2017, 12:30
Óscar
Thank you very much Knusper. I got it after a couple of days
Old   August 1, 2017, 03:10
Siddharth
Sid! is on a distinguished road
Hi Oscar,
I'm trying to use sampleDict and get the same message:
type sets;
and run
Could you please let me know the changes you made to get it to work?
Thanks
Siddharth
Sid! is offline   Reply With Quote
Old   August 1, 2017, 15:15
Bazinga is on a distinguished road
Originally Posted by Sid! View Post
Hi Oscar,
type sets;
and run
Thanks
Siddharth
What exactly does not work? Did you copy the text to the sampleDict file? How did u try to run sample? Maybe upload the file so we can help.
Sent from my SM-G950F using CFD Online Forum mobile app
Bazinga is offline   Reply With Quote
Old   August 17, 2017, 02:52
Siddharth
Sorry for the late reply.
It's working now. Made a mistake in the sampleDict file.
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 03:48
[ANSYS Meshing] Periodicity problems in icem zeeshu ANSYS Meshing & Geometry 0 April 17, 2016 21:59
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 13:13
Cyclic patches and parallel postprocessing problems askjak OpenFOAM Bugs 18 October 27, 2010 04:35
[OpenFOAM] ParaView Postprocessing problems with cyclic boundaries christian ParaView 10 June 26, 2009 06:49
