Airfoil simulation wrong pressure field at some angles of attack |
December 14, 2016, 12:53 |
Lorenzo Donisi
Rep Power: 10 |
Hi everybody,
I am trying to simulate the flow field around a NACA 0012, using OpenFOAM (simpleFoam), at Re=6e6. I am using the SST k-omega model, with an average y+ around 30, using wall functions. The lift and drag coefficient I get are quite good if compared with xFoil and other sources. The strange problem I am experiencing is a wrong pressure field for some angles of attack, namely 4deg and 7deg. I really cannot wonder why this is happening, or maybe the pressure fields are correct; I hope you can give me an answer in any case. PS: is there a better utility than wallPressure to output the pressure or maybe the pressure coefficient over the airfoil? |
December 14, 2016, 12:55 |
Lorenzo Donisi
Rep Power: 10 |
These are the speed fields, I could not load all the images in the same post
airfoil, pressure, pressure coefficient |
Pressure drop in pipe flow with Large Eddy Simulation | xerox | FLUENT | 1 | October 16, 2019 09:55 |
Oscillating pressure field of 2D airfoil | TypeR | OpenFOAM Running, Solving & CFD | 0 | June 15, 2016 15:16 |
Bad cd at high angles of attack | 2d airfoil | koalabryant | FLUENT | 0 | August 18, 2015 08:44 |
Airfoil simulation in High Angles of Attack | Yasser Nabavi | FLUENT | 0 | April 21, 2006 18:28 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
