Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculation of drag coefficient in porous zone
Old   November 30, 2016, 13:25
Default Calculation of drag coefficient in porous zone
Anirudh Kulkarni
Tempest is on a distinguished road
Dear foamers,
How can I calculate drag coefficient for porous zone without using forceCoeffs macro in controlDict.
One option is to take the difference of average pressure at the front and rear face of the body for pressure drag. And for viscous drag difference of du/dy at top and bottom face of body.
I can extract pressure values by using sampleDict. But I am not able to extract du/dy.
I am defining volTensorField gradU = fvc::grad(U)
volScalarField dUdy = gradU.component(tensor::YY)
But I am not sure this is correct. Please help me out here.
Tempest is offline   Reply With Quote
Old   December 16, 2016, 05:13
Huynh Phong Thanh
hiuluom is on a distinguished road
1. You can extract porous region by using foamToVTk.
you can refer the link here. How to visualize cellset region in OF?
2. Using paraview to openfoam porous region and then refer the link to calculate the force:
https://www.simscale.com/docs/conten...ce-computation
hiuluom is offline   Reply With Quote
Old   January 20, 2017, 18:52
Default non-porous drag forces on porous sphere
pantalaimon is on a distinguished road
I am attempting to compute the forces on a porous sphere in laminar flow conditions using OF.
I can produce the flow field fine, and I can compute the porous forces within the porous sphere via controlDict, specifying the cellZone. However the forces that I am interested in are the non-porous drag forces: i.e., the drag forces due to the delta pressure on the front and rear of the sphere and skin friction, which are derived from variables outside the cellZone.
I thought that I could follow the above suggestions. In paraview, it's easy to view the cellZone by itself, as per the first suggestion. However, paraview seems to be unable to "Generate Surface Normals" for the cellZone as suggested here.
Does this feature only work with cellSets, as per tutorial, or has anyone got it working for cellZones?
Or indeed, has anyone a different suggestion for the computation of the (non-porous) drag force on a porous body?
Cheers!
pantalaimon is offline   Reply With Quote
Old   February 8, 2019, 14:21
mechy is on a distinguished road
Originally Posted by pantalaimon View Post
Cheers!
Hello
Dear pantalaimon
I have the same problem
do you find it's solution ?
Best Regards
mechy is offline   Reply With Quote
Old   February 16, 2019, 08:30
Default same problem
zein elserfy
zeinelserfy is on a distinguished road
does anyine find a solution for that case?
zeinelserfy is offline   Reply With Quote
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
drag coefficient calculation Konstantine OpenFOAM Running, Solving & CFD 9 September 23, 2014 14:55
calculation of Drag Coefficient in CFX? ganesh chakravarthi CFX 5 May 28, 2014 19:54
Lift and Drag calculation if wing is porous in nature mooby FLUENT 5 May 12, 2014 10:50
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 13:25
