Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Density(rho) in compressibleInterFoam
Old   November 15, 2016, 13:12
Default Density(rho) in compressibleInterFoam
Jue Wang
Joe Wang is on a distinguished road
Hi, Foamers,
I would like to integrate the air mass in a certain domain solved with compressibleInterFoam. Since air phase is compressible, an approximate way I would use is let
rho_air = rho - alpha.water * rho_water
where I assume rho_water is a constant when alpha.water equals to 1.
However, when I checked the calculation results, it's not true. rho_water changes along with pressure changing. I thought compressibleInterFoam only takes gas as the compressible phase. Am I wrong?
And regardless of I'm correct or wrong, does someone know how to calculate the gas mass in a certain domain in a multi-phase flow field?
Hope someone knows more about the hypothesis of this solver and clear up my confusion. Thanks.
Joe
Joe Wang is offline   Reply With Quote
air compressibility, compressibleinterfoam, density, mass
