Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating Lift and Drag Coefficients: All 0?
Old   October 22, 2016, 14:03
Default Calculating Lift and Drag Coefficients: All 0?
Peter
APCoding is on a distinguished road
I'm trying to calculate lift and drag coefficients on the propeller test case (in pimpleDyMFoam). I seem to have gotten it working with no errors, but forces.dat just contains 0s. Here is the file:
# Forces
# CofR       : (2.500000e-01 0.000000e+00 0.000000e+00)
# Time       forces(pressure viscous porous) moment(pressure viscous porous)
0.000333333  	((0.000000e+00 0.000000e+00 0.000000e+00) (0.000000e+00 0.000000e+00 0.000000e+00) (0.000000e+00 0.000000e+00 0.000000e+00)) ((0.000000e+00 0.000000e+00 0.000000e+00) (0.000000e+00 0.000000e+00 0.000000e+00) (0.000000e+00 0.000000e+00 0.000000e+00))
Here's the config file (or whatever it's called):
forces
    type                forces;
    functionObjectLibs  ("libforces.so");
    outputControl       timeStep;
    outputInterval      1;
    patches             ( “propellerStem1.*” );
    pName               p;
    UName               U;
    rhoName             rhoInf;
    log                 true;
    CofR                (0.25 0 0);
    rhoInf              1;
forceCoeffs
    type                forceCoeffs;
    functionObjectLibs  ( "libforces.so" );
    outputInterval      1;
    pName               p;
    UName               U;
    rhoName             rhoInf;
    log                 true;
    liftDir             (0 0 1);
    dragDir             (-1 0 0);
    CofR                (0.25 0 0);
    pitchAxis           (0 1 0);
    magUInf             2.00;
    rhoInf              1000;
    lRef                1;
    Aref                1;
What makes it all 0? Am I measuring from the wrong place? Should I somehow measure the whole propeller? How would I do that? Thanks for your help!
APCoding is offline   Reply With Quote
Old   October 30, 2016, 13:51
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Originally Posted by APCoding View Post
# Forces
forces
    type                forces;
    outputInterval      1;
    pName               p;
    UName               U;
    rhoName             rhoInf;
    log                 true;
    CofR                (0.25 0 0);
    rhoInf              1;
forceCoeffs
    type                forceCoeffs;
    outputInterval      1;
    pName               p;
    UName               U;
    rhoName             rhoInf;
    log                 true;
    liftDir             (0 0 1);
    dragDir             (-1 0 0);
    CofR                (0.25 0 0);
    pitchAxis           (0 1 0);
    magUInf             2.00;
    rhoInf              1000;
    lRef                1;
    Aref                1;
You need to stick with one density. In the quoted script, you defined rhoInf 1 and then you defined it again below but rhoInf 1000. Have you noticed that?
Best,
tareqkh is offline   Reply With Quote
force coefficients
Generating the lift and drag coefficients with openFOAM JackJewell OpenFOAM 0 June 14, 2016 10:36
calculating lift and drag coefficients _ running in parallel Mike_star OpenFOAM Programming & Development 1 April 4, 2016 12:16
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 19:31
Great lift coefficients but negative drag coefficient?! nez FLUENT 0 November 28, 2011 14:57
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 15:45
