Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Finding volume of fragmented droplets
Old   October 14, 2016, 14:32
Default Finding volume of fragmented droplets
Saideep
Saideep is on a distinguished road
Hi guys;
I am using interFoam to study microchannel flows, droplet fragmentation etc. I would like to know how can I get the volume of droplet fragmented? For example as shown in fig1.jpg.
I see some papers such as in "Benchmark numerical simulations of segmented two-phase flows in microchannels using the Volume of Fluid method" who used interFOAM and probably paraview as a post-process tool. Is there a function in paraview that can do the job?
Thanks;
Saideep
Saideep is offline   Reply With Quote
Old   October 26, 2016, 07:21
Brian Willis
Dipsomaniac is on a distinguished road
Hi Saideep
I don't think there is a simple way to automate it. And depending on how much data you need, it may be easiest just to manually find the volume using Paraview. I would use a box to cut out the region wherein you find the blob, then cut by the scalar value of alpha, integrate over the remaining region to extract the volume of the blob. You could even allow this run over the whole simulation and take the maximum volume which will be period with the blobs being formed, if they are similar every time.
Regards,
Brian
Dipsomaniac is offline   Reply With Quote
droplets volume, paraview, post-process
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Finding Volume fraction at outlet when it changes its phase. praveen.jpk Main CFD Forum 1 August 18, 2014 08:18
[Commercial meshers] CuBit t42 OpenFOAM Meshing & Mesh Conversion 6 July 10, 2008 08:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
