Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Forces, moments and torque calculation
Old   September 26, 2016, 14:23
Question Forces, moments and torque calculation
Asmaa
foamiste is on a distinguished road
Hello foamers,
I am simulating a multiphase flow in a stirred tank using the solver multuphaseEulerFoam. And I want to calculate the forces and the moments applied on the impeller in order to calculate the torque.
Did someone have an idea about how to calculate these parameters?
Any help will be appreciated
foamiste is offline   Reply With Quote
Old   October 6, 2016, 08:47
Default function with type forces
APOcfd is on a distinguished road
I'm a beginner user of OpenFOAM, so I'm not really sure what I'm telling you.
I had a similar problem. I run an incompressible steady-state case (simpleFoam) and I added, in the controlDict, the function in the attachment...
You will get a file with the three components (x,y,z) of force and moment at every time step.
Bye
APOcfd is offline   Reply With Quote
Old   October 7, 2016, 07:12
Asmaa
Thank you for your response, well it is true, this script can be added, i worked with it using the solver simpleFoam. But for multiphase solvers, it doesn't work. & I don't know why..
Old   May 23, 2017, 18:45
Felipe Carreņo
faclopez is on a distinguished road
Hello! im trying to do the same, have you solved that problem?
kind regards
faclopez is offline   Reply With Quote
Old   May 24, 2017, 06:14
Asmaa
No, unfortunately I didn't solve the problem.
If you find something, please share it with us.
Good luck!
Old   October 7, 2022, 05:16
Adriano Scarano
Adriano27 is on a distinguished road
Hi guys!
I have the same problem. Any news about how to solve it? That's for my master thesis and I really need help pleeeasse.
BR,
Adriano
Adriano27 is offline   Reply With Quote
[Help!] impeller torque calculation: pressure and viscous moments ghost82 Main CFD Forum 1 March 27, 2014 03:37
simpleSRFFoam and forces macbeth OpenFOAM Running, Solving & CFD 7 February 20, 2014 04:17
UDF for torque (easy) elcino Fluent UDF and Scheme Programming 0 May 17, 2012 12:39
Calculating torque Andrew FLUENT 5 September 4, 2007 12:10
torque calculation baned FLUENT 1 August 29, 2003 13:53
