Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
total pressure drop computation
Old   September 26, 2016, 12:42
Default total pressure drop computation
APOcfd is on a distinguished road
Hi everybody,
I'm a beginner user of OpenFOAM.
I need to compute the total pressure drop in a pipe but I can't do it.
Till now I have followed some examples found on this forum (http://www.cfd-online.com/Forums/ope...tml#post430031) but the total pressure on the outlet patch is always zero.
Can anyone suggest me a procedure to follow please? Give me examples?
Can be enogh using the function objects or should I use swak4Foam?
Thanks in advance,
Alessandro
APOcfd is offline   Reply With Quote
Old   October 6, 2016, 07:27
Default Total pressure drop test
I tried to build an expression with swak4Foam, can anyone tell me if it is right?
total pressure, total pressure drop
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Difference between total pressure, total pressure in Stn and in Rel frames turbo5 CFX 6 January 21, 2016 17:05
a problem in calculating pressure drop in Fluent? yu chun FLUENT 1 May 18, 2004 04:40
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
