August 23, 2016, 06:34 |
Forces and ForcesCoeffs mismatch
Jean-Pierre
Hi everyone,
I have some problems with the calculation of coefficients (lift for now). I am using two methodologies that are not giving the same results : For the fist one I take the forces values from forces.dat. I sum the pressure, viscous and porous forces along the same axis (in my case z) to get the total force. Then I divide this total force by 0,5*rho*S*U*U to get my coefficient. For the second methodology I just use forceCoeffs providing the same values for rho, S and U of course. The second methodology is the one that match best the exp. results. I made my research and found that the value given by the second methodology is rho times bigger than the value from the first : Cl_methodology2 = Cl_methology1*rho. I also know that OpenFOAM does not give the pressure directly but P/rho. My hypothesis is that the forces from forces.dat are also divided by rho. I tried to confirm this by looking into forces.c and forceCoeffs.c but I didn't understood well. Could someone tell me if my hypothesis is ok or is anything else happening? Thank you very much!! Jean-Pierre Last edited by JPMtz; August 23, 2016 at 07:52. |
coefficients, forces and force coeff., post processing, rho |
forcesCoeffs - how to use relative pressure instead of absolute pressure | WhiteW | OpenFOAM Running, Solving & CFD | 2 | December 22, 2015 13:40 |
Forces printout for multiple patches | ozzythewise | OpenFOAM Pre-Processing | 3 | March 7, 2012 13:59 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 08:11 |
