Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculate the submerged volume of floating body
Old   August 22, 2016, 09:33
Default Calculate the submerged volume of floating body
mo_na's Avatar
Mona
mo_na is on a distinguished road
Hey everyone,
I would like to calculate the submerged volume of a floating body (in my case a body pitching around a hinge).
It doesn't need to be at runtime. For me it would be enough to calculate it in its rest position at the beginning of the simulation.
The reason why I want to do this is that the rest angle I obtain during a free decay test doesn't match the rest angle that I calculated before using the submerged volume I got from Wamit. Thats why I want to check now if the submerged volume is how its supposed to be.
I would very much appreciate any help!
Cheers,
Mona
mo_na is offline   Reply With Quote
Old   May 20, 2017, 04:09
raju ram bhakar
bhakar.raju98 is on a distinguished road
Hello Mona,
Have you figured it out how to calculate the underwater volume or volume of some body in paraview or openfoam.
I am having a DTC Hull and want to calculate the volume of the hull.
bhakar.raju98 is offline   Reply With Quote
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 04:23
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
Floating body: explosions in the sky Phicau OpenFOAM Running, Solving & CFD 1 February 4, 2014 05:37
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
