Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
postProcess functionality in openFOAM 4
Like Tree18Likes
Old   August 15, 2016, 04:46
Default postProcess functionality in openFOAM 4
Gareth
bullmut is on a distinguished road
Hi All
I am switching to openFOAM 4 from 2.3.1
Currently working on the postProcess utility. I have run the motorbike tutorial to get a understanding on the new syntax. I then disabled the #inlcude files in the controlDict. I did this to try and run those files through the postProcess utility. I had sucess with
"streamlines" -
postProcess -func streamLines
and
"cuttingPlane" -
postProcess -func cuttingPlane
However
"forceCoeffs" -
postProcess -func forceCoeffs
and
"wallBoundedStreamLines" -
postProcess -func wallBoundedStreamLines
wont work directly.
so this is a two part question. Can anyone explain why these files wont work through this utility? In the case of the the forceCoeffs file i get the following error:
--> FOAM FATAL ERROR:
Could not find U, p
and for the wallBoundedStreamLines, the error that pops up revolves around it not seeing a UNear field in the time folder.
Cannot find field UNear
Valid scalar fields are:
2
k
p
Valid vector fields are:1(U)
But within the file itself it asks OF to make the UNear field.
So i then tried to run the nearWallField section of the file alone. I have not altered the file in anyway, i cut the one dictionary out form the original wallBoundedStreamLines file, and ran the code attached and got the following error
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 19 the punctuation token '('
file: /home/erfort/OpenFOAM/erfort-4.0/tutorials/incompressible/simpleFoam/motorBike/system/near.near.fields at line 19.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
    in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
Then i removed the brackets around the field specification and got this...
Expected a '(' while reading Tuple2, found on line 19 the word 'U'
    From function Foam::Istream& Foam::Istream::readBegin(const char*)
    in file db/IOstreams/IOstreams/Istream.C at line 92.
Any advice on what is going on? I have read through the documentation with no success. Am i using this utility right? If the file has more than one subdictionary (like in wallboundedStreamLines) should i change the command line? How come forcesCoeff doesnt see fields that are present in the time directory?
I look forward to the replies
Regards
File Type: txt near.txt (527 Bytes, 71 views)
bullmut is offline   Reply With Quote
Old   August 18, 2016, 09:14
igor.leo93's Avatar
Igor Leonardo
igor.leo93 is on a distinguished road
Hello
Take a look here:
http://cfd.direct/openfoam/user-guid...#x31-2270006.2
For the first function, try this :
postProcess -fields "(p U)" -func forceCoeffs
About that second one i'm not sure, but i will take a look at it later.
Regards,
Igor Carvalho
lincui, purnp2 and saladbowl like this.
igor.leo93 is offline   Reply With Quote
Old   August 18, 2016, 09:36
Gareth
Hi Igor
Thanks for the reply,
I tried using the line you suggested, it now reads the fields , but got the following reply
No valid model for viscous stress calculation
    From function Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::functionObjects::forces::devRhoReff() const
I noticed at the post you directed me to, was the built in fucntion file for forcecoeffs.
I then ran the following line
postProcess -func 'forcesIncompressible('bladeBot',p,U)'
And got the same error. so i think i need to add into my fvSchemes file a definition for "devRhoReff", correct?
Full output in attachment
Regards
Old   August 18, 2016, 10:12
igor.leo93's Avatar
Igor Leonardo
Hello
Well i'm not quite sure my friend.
I never had to use that function before so i can't say for sure, but i think that is correct, try that.
Let us know if it works.
Regards
Old   September 4, 2016, 14:45
Gareth
solution... READ THE USER GUIDE.
So while i have read the user guide more than once, they tend to update along with the openFOAM versions.
The solution to my problem was to add the solver info.
simpleFoam -postProcess -func 'forces' -latestTime
The solver then provides field information as well as turbulence model.
Had i read the book... i would see said answer.
Thanks Igor for the help though. Each step counts!
Hope this helps someone eventually
Old   September 4, 2016, 14:56
igor.leo93's Avatar
Igor Leonardo
Yeah nice.
Now that i look at the error you were getting i realize that the solver info was needed, it is good habit perhaps, to also use the solver info on all functions for postprocessing.
Best regards,
Igor
Old   September 21, 2016, 04:42
Default How to specify patch name
Dan Nielsen
Dan N is on a distinguished road
Hey All
I am trying to use the postProcess utility to calculate a patch average by using:
postProcess -func 'patchAverage'
it tells me that it needs a patch name:
surfaceRegion patchAverage: patch(<patchName>):
Unknown patch name: <patchName>. Valid patch names are:
3
movingWall
fixedWalls
frontAndBack
But it seems that i cant finde a way to specify that patch name, can anyone help me?
Dan N is offline   Reply With Quote
Old   September 21, 2016, 04:54
Gareth
Hi Dan
After you specify the function you also need to tell it where to look.
try the following
postProcess -func "patchAverage(field,name=fixedWalls)"
The field you are interested in will be called on the patch you named
Old   September 21, 2016, 08:57
Dan Nielsen
Hi bullmut
Thanks it works.
Dan.
Old   November 24, 2016, 12:26
Default how to calculate grad(rho)&grad(U)
harvee is on a distinguished road
Hey all
I want to calculate the gradient of density and velocity.
Here is what I type:
postProcess -fields '(rho U)' -func 'grad'
Returns:
Reading fields:
volScalarFields: rho
volVectorFields: U
Executing funtionObjects
-->FOAM Warning : fuctionObject grad: Cannot find require field <fieldName>
anyone know how to fix it?
Thanks
harvee is offline   Reply With Quote
Old   November 24, 2016, 13:04
Gareth
Hi Harvee
Try the line
postProcess -func "grad(U)"
It should act through the whole field and save the field to each time step.
Old   November 24, 2016, 13:16
Hi bullmut
thanks for the quick reply.
I tried your code get I get this:
Executing functionObjects
--> FOAM Warning :
From function bool Foam::functionObjects::regionFunctionObject::store (Foam::word&, const Foam::tmp<T>&, bool) [with ObjectType = Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>]
in file home/OpenFOAM/OpenFOAM-4.0/src/OpenFOAM/lnInclude/regionFunctionObjectTemplates.C at line 61
Cannot store cache-able field with the named used in the cache.
Either choose a different name or cache the field and use the 'writeObjects' functionObject.
--> FOAM Warning : functionObject grad: Cannot find required field U
I tried a lot of combination of fields and func ,none of them worked.
and when I try to get grad(rho), the rho file doesn't exist in my 0 folder since I'm using
rhoCentralFoam, I thought that maybe affect the searching of rho, do you know how to calculate rho for 0 folder btw?
Old   November 28, 2016, 00:48
Default Lift Coeff error
  #13
H salem
hsalem is on a distinguished road
Hi Dear friends,
I have problem with using post processing tool. When I want to use the Force coefficient tool to find out about Cl, Cd, Cm there is problem with this type:
Could not find rho
From function void Foam::functionObjects::forces::initialise()
in file forces/forces.C at line 197.
FOAM exiting
Any idea?
this is my Code:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Web: www.OpenFOAM.org
\\/ M anipulation |
Description
Calculates lift, drag and moment coefficients by summing forces on
specified patches for a case where the solver is incompressible (pressure
is kinematic, e.g. m^2/s^2).
forces
type forces;
functionObjectLibs ("libforces.so");
writeControl timeStep;
writeInterval 10;
patches ( "airfoil.*" );
pName p;
UName U;
rhoName rhoInf;
log true;
CofR (0.25 0 0);
rhoInf 1.284;
forceCoeffs
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
writeInterval 10;
pName p;
UName U;
rhoName rhoInf;
log true;
liftDir (0 1 0);
dragDir (1 0 0);
CofR (0.25 0 0);
pitchAxis (0 0 1);
magUInf 6.69;
rhoInf 1.284;
lRef 1;
Aref 1;
hsalem is offline   Reply With Quote
Old   November 28, 2016, 02:40
Default Calculate grad(U) & MachNo
  #14
Hey there!
grad(U) func seems can only deal one time directory once a time.
Until the bug is resolved, you can only calculate grad(U) for one time directory. You can add one of the time options, e.g -time <timeDir> or -latestTime, to select a specific time directory. For all time directories, the following will work in the meantime,make a script and put this in:
for d in $(foamListTimes) ;
do postProcess -time $d -func "grad(U)" ;
done
Additional info:
for machNo
solvername -postProcess -func MachNo
many command seems need to specify the solvername. The point about Mach number is you cannot do "pure" post-processing using data in time directories, because it also requires thermophysical models.
Old   November 28, 2016, 02:44
try this:
<solvername> -postProcess -func "forceCoeffsCompressible"
Old   November 28, 2016, 12:23
H salem
Thank you harvee for your time.
your suggestion will work after the simulation is done. but I this problem doesn't let the simulation start. am I right? if not, where should I include your suggestion?
Old   November 28, 2016, 12:34
hi hsalem
Maybe I misunderstood your problem.
you're right,my case is doing some post-process after the simulation is done.
I've never used Run-time data processing.sorry I can't help you.
the only thing I can find related is on this page:http://cfd.direct/openfoam/user-guid...#x31-2270006.2
let me know if you figure it out.
Old   November 28, 2016, 12:39
H salem
Dear Harvee,
Thank you. Yes I have found the solution. it seems that I was using the old method of finding the force coefficients. in openfooam 4, there is a package that let you use it more easily. all you need is to see the user guide section 6.2.2.
Old   January 1, 2017, 18:29
Default Gradient of Field - Gradient of Velocity in OpenFoam
  #19
Vijaya Kumar. G
VIJAYA KUMAR is on a distinguished road
Dolution
After lots of trouble this works
I used in pimpleFoam solver. In OF4.0 it is necessary to specify the solver name
pimpleFoam -postProcess -func "grad(U)"
VIJAYA KUMAR is offline   Reply With Quote
Old   January 17, 2017, 11:14
Endel is on a distinguished road
Helly everyone,
I am trying to calculate the rho field from a sonicFoam case.
In previous versions of OpenFOAM this was apparently possible using
execFlowFunctionObjects
as described here:
https://www.cfd-online.com/Forums/op...tml#post254920
In OF4 however, this doesn't seem to work anymore and the following message appears:
execFlowFunctionObjects has been superceded by the '-postProcess' solver command-line option
I still can't figure out how to calculate the rho field by either using the postProcess utility or the former solution above.
Any help is highly appreciated, thank you very much!
Endel is offline   Reply With Quote
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 05:57
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
