Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Sampling on moving planes
Old   August 11, 2016, 21:17
Default Sampling on moving planes
Tarak
Tarak is on a distinguished road
I am currently doing a wind turbine simulation using pimpleDyMFoam solver, where the blade rotation is achieved through a rotating cylindrical cellSet (which rotates w.r.t. a static outer mesh).
Now, I want planes of data from different spanwise sections of the blade during the post-processing step within openFoam (to analyse the local boundary layer), but finding it difficult as this sampling needs to be done on moving planes. Can someone suggest me an efficient method to carry this out?
Tarak is offline   Reply With Quote
Old   August 12, 2016, 06:43
Mohammed Gowhar
mdgowhar is on a distinguished road
Hi Tarak,
Could you tell me whether you want during runtime or after once you got the solution which is saved in your local?
If you want during runtime, I dont think OpenFOAM has manageable Co-ordinate System which commercial software has it.
Once you have a solution in your local, you could use macro in paraview to get the plane sections across your blade. (Using Transform from Filter Menu).
According to the timeStep you knew the Blade Position, and it is repeated one. These values are input for Transform.
I hope you got the point.
If you have any doubt or require any further clarifications, please feel free to let me know.
Regards,
Gowhar
mdgowhar is offline   Reply With Quote
sampling interval and sampling frequency beauty FLUENT 13 November 9, 2022 09:23
sampling when mesh has moving points Phicau OpenFOAM Post-Processing 6 March 4, 2013 12:36
[snappyHexMesh] jagged, ragged edges... ziemowitzima OpenFOAM Meshing & Mesh Conversion 138 July 24, 2012 00:41
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 07:54
Moving mesh in Fluent fivos FLUENT 0 April 2, 2010 10:45
