Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Error while running sample utility
Old   July 15, 2016, 12:19
Default Error while running sample utility
usv001 is on a distinguished road
Dear all,
I am trying to use the sample utility to get a cross section of my 3D case. Here is my sampleDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      sampleDict;
setFormat raw;
surfaceFormat vtk;
formatOptions { }
interpolationScheme cellPoint;
fields ( p U );
sets ( );
surfaces
    xNormal
        type            plane;
        basePoint       (0 0 0);
        normalVector    (1 0 0);
        interpolate     true;
It has been working fine on my PC until recently. The process keeps getting 'Killed' most likely due to insufficient memory. But I am not sure why it worked fine earlier though...
So, I tried running it in a HPC and it resulted in the following error:
Build  : 2.4.0-dcea1e13ff76
Exec   : sample -latestTime
Date   : Jul 15 2016
Time   : 22:55:33
Host   : "std1621"
PID    : 20741
Case   : /home/users/ntu/m150086/OpenFOAM/JET/atmosphere/ref_1
nProcs : 1
sigFpe : Floating point exception trapping - not supported on this platform
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0.002
Reading surface description:
    xNormal
Time = 0.002
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib64/libc.so.6"
#3  Foam::cuttingPlane::calcCutCells(Foam::primitiveMesh const&, Foam::Field<double> const&, Foam::UList<int> const&) at ??:?
#4  Foam::cuttingPlane::reCut(Foam::primitiveMesh const&, bool, Foam::UList<int> const&) at ??:?
#5  Foam::sampledPlane::update() at ??:?
#6  Foam::sampledSurfaces::update() at ??:?
#7  Foam::sampledSurfaces::write() at ??:?
#8  ? at ??:?
#9  __libc_start_main in "/lib64/libc.so.6"
#10  ? at ??:?
[std1621:20741:0] Caught signal 11 (Segmentation fault)
==== backtrace ====
 2 0x0000000000059e9c mxm_handle_error()  /var/tmp/OFED_topdir/BUILD/mxm-3.4.3065/src/mxm/util/debug/debug.c:641
 3 0x000000000005a00c mxm_error_signal_handler()  /var/tmp/OFED_topdir/BUILD/mxm-3.4.3065/src/mxm/util/debug/debug.c:616
 4 0x0000003b84a326a0 killpg()  ??:0
 5 0x0000003b84a32625 raise()  ??:0
 6 0x0000003b84a326a0 killpg()  ??:0
 7 0x00000000001ebc65 _ZN4Foam12cuttingPlane12calcCutCellsERKNS_13primitiveMeshERKNS_5FieldIdEERKNS_5UListIiEE()  ??:0
 8 0x00000000001eb72d _ZN4Foam12cuttingPlane5reCutERKNS_13primitiveMeshEbRKNS_5UListIiEE()  ??:0
 9 0x0000000000232cad _ZN4Foam12sampledPlane6updateEv()  ??:0
10 0x0000000000342c81 _ZN4Foam15sampledSurfaces6updateEv()  ??:0
11 0x0000000000343a03 _ZN4Foam15sampledSurfaces5writeEv()  ??:0
12 0x00000000004067a9 main()  ??:0
13 0x0000003b84a1ed5d __libc_start_main()  ??:0
14 0x0000000000405ad9 _start()  ??:0
I am not sure what to make of the error. Any help would be appreciated.
Thanks to everyone.
usv001 is offline   Reply With Quote
Old   November 16, 2018, 10:06
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by usv001 View Post
Dear all,
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      sampleDict;
setFormat raw;
surfaceFormat vtk;
formatOptions { }
fields ( p U );
sets ( );
surfaces
    xNormal
        type            plane;
        basePoint       (0 0 0);
        interpolate     true;
Date   : Jul 15 2016
Time   : 22:55:33
Host   : "std1621"
PID    : 20741
nProcs : 1
Create time
    xNormal
Time = 0.002
#8  ? at ??:?
#10  ? at ??:?
==== backtrace ====
Thanks to everyone.
I'm having the exactly same error when sampling a surface. Did you find any solution?
Thanks,
Syavash
syavash is offline   Reply With Quote
Old   November 16, 2018, 10:23
I didn't manage to find a solution. Thankfully, the HPC people had compiled OpenFOAM v3.0 which worked fine. I believe that there are some incompatibilities with my compilation of OpenFOAM v2.3 and the libraries in the HPC but I cannot be too sure.
USV
Old   November 16, 2018, 13:51
Ehsan Asgari
USV
Thanks for your reply. As I am also using OF 2.3.1 I guess it should be a problem related to the old version.
Regards,
Syavash
sample surface, sample utility, vtk
Problem with running chtMultiRegionFoam after using setSet utility Victor OpenFOAM 12 March 24, 2023 01:01
running utility command every timeStep TReviol OpenFOAM Running, Solving & CFD 1 June 25, 2013 10:21
double output of sample utility letzel OpenFOAM Post-Processing 0 March 12, 2013 07:10
sample utility surfaceformat as grid data for gnuplot circular crosssection cfddwarf OpenFOAM Post-Processing 0 July 13, 2012 10:05
Understanding the coordinates of sample utility vishwa OpenFOAM Post-Processing 4 March 25, 2010 13:51
