Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] post-processing chtMultiRegionFoam case in paraview?
Like Tree2Likes
  • 1 Post By phsieh2005
  • 1 Post By jmdf
Old   July 15, 2016, 09:25
Default post-processing chtMultiRegionFoam case in paraview?
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear OpenFOAMers,
I ran a chtMultiRegionFoam case. And the case was decomposed into 16 processors. I used to reconstruct the case and then use foamToVTK to convert each region into VTK format. Is there a quick way to post-process a multiRegion case without first reconstruct and converting to VTK?
Thanks!
Pei-Ying
jadidi.cfd likes this.
phsieh2005 is offline   Reply With Quote
Old   July 15, 2016, 13:44
Joćo Ferreira
jmdf is on a distinguished road
I usually post-process multi region cases using:
paraFoam -builtin
Launching paraFoam with this flag, it loads all regions. I used paraView 4.4.0, not sure if it works with every version.
Note that you need to reconstruct the case first.
Have fun!
jmdf is offline   Reply With Quote
Old   July 15, 2016, 16:05
Bloerb will become famous soon enough
As mentioned paraFoam -builtin
You do not need to reconstruct the case. You can simple switch to decomposedCase as usual in paraview
Some small pointers though.
If you have created your mesh from a single constant/polyMesh domain by splitting it with splitMeshRegions you should remove or rename this because it will show up in paraview.
If you only want to postProcess one domain it works the same way. Once paraview is open just uncheck all the domains you do not need.
Bloerb is offline   Reply With Quote
fluent DPM - post processing ParaView gigivmasche FLUENT 4 October 23, 2019 04:05
how to create at circular surface in a flunet case for post processing novic FLUENT 1 December 26, 2016 00:19
Post processing in CFD Post or Fluent. Blobs OpenFOAM Post-Processing 2 June 26, 2016 08:23
[General] Flow3d post processing with ParaView Rajiv Kothari ParaView 0 May 24, 2007 10:00
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
