June 28, 2016, 02:00 |
Executing sampling
Zhifang Hu
Rep Power: 11 |
Hi there
Just a quick question, is it possible to execute sample function (with sampleDict in the system folder) the same time when the simulation is still running. For instance. I have a simulation run for 100s with 2s written interval. So when the simulation is running, with some results folder creating, like folder 2, 4 etc. the sample function also starts executing, creates results at postProcess directory with folder 2, 4 etc. If its possible, could i have an example of that. Thanks in advance. |
sampling interval and sampling frequency | beauty | FLUENT | 13 | November 9, 2022 09:23 |
Possible bug or limitation in stl-generated surface for sampling analysis | Ali Blues | OpenFOAM Post-Processing | 3 | April 27, 2016 10:30 |
Runtime sampling along a time-dependent line | Gaetano | OpenFOAM Programming & Development | 4 | January 31, 2014 08:46 |
sample utility stops sampling once the line leaves the domain | Zymon | OpenFOAM | 1 | May 2, 2012 05:51 |
sampling Data during calculation | JimKnopf | OpenFOAM Post-Processing | 0 | May 27, 2011 05:10 |
