Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallHeatFlux calculation
Old   June 24, 2016, 18:38
Question wallHeatFlux calculation
cfdsolver1 is on a distinguished road
Hello everyone. I am beginner level OpenFOAM user. I am trying to simulate my 3D problem in 2D domain to get used to the environment and solvers of OpenFOAM. I tried to draw my problem in this file: http://imgur.com/iEHWKoU
I need to import STL file in my real problem; so imported solid.STL file and mesh it by using blockMesh and snappyHexMesh. I have inlet, outlet, slip and fixedWall boundaries in my problem. I solved this problem using buoyantBoussinesqSimpleFoam and obtained U and T values at each point. Now, what I want to do is calculating wall heat flux at fluid-solid interface.
I have an experience in Fluent; so in Fluent, I need to have an interface boundary between fluid and solid to evaluate wall heat flux. How this can be done in OpenFOAM? Do I need to have an interface to calculate wall heat flux in OpenFOAM or it handles this automatically, somewhow? Do I need another solver to obtain wall heat flux or can I obtain it by using buoyantBoussinesqSimpleFoam solver?
I have checked several tutorials online and I am very confused so any help is appreciated.
cfdsolver1 is offline   Reply With Quote
openfoam, wallheatflux
Dynamic mesh adaption in parallel calculation xh110120 FLUENT 1 March 12, 2016 09:05
Determining the calculation sequence of the regions in multe regions calculation peterhess OpenFOAM Running, Solving & CFD 4 March 9, 2016 04:07
wrong calculation of wallHeatFlux utility in solid patches zfaraday OpenFOAM Post-Processing 6 January 12, 2016 17:39
wallHeatFlux utility with sonicFoam hiuluom OpenFOAM Post-Processing 3 September 18, 2015 08:39
Warning 097- AB Siemens 6 November 15, 2004 05:41
