March 18, 2016, 16:09 |
Postprocessing utility R not working
Amitabh
Rep Power: 13 |
I just installed foam-extend 3.1 on my Mac OS and I'm trying to run turbulent channel flow using Launder Sharma k-epsilon model. pisoFoam runs fine, but when I use the "R" utility, I do not see the Reynolds stresses in the output directories. I also don't get any error. Any help with this will be appreciated.
Here's the output from "R" command: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.1 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.1-6c0c77dee21a Exec : R Date : Mar 19 2016 Time : 01:38:58 Host : Amitabhs-MacBook-Pro.local PID : 11328 CtrlDict : /Users/Amitabh/foam/foam-extend-3.1/etc/controlDict Case : /Users/Amitabh/foam/Amitabh-3.1/run/channel_LSke nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model LaunderSharmaKE LaunderSharmaKECoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Calculating the Reynolds Stress R End |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 6 | November 15, 2014 19:04 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
StreamFunction utility | titio | OpenFOAM Post-Processing | 0 | May 19, 2010 17:04 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 0 | February 5, 2010 13:12 |
Sample utility not working in OpenFoam1.5 dev | titio | OpenFOAM Post-Processing | 1 | December 10, 2009 03:38 |
