Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Massflow rate at inlet and outlet different | conservation of mass
Old   March 18, 2016, 04:26
Default Massflow rate at inlet and outlet different | conservation of mass
Manoj
manoj_nav is on a distinguished road
Dear All,
I am trying to simulate ventilation in ship cargo space. For this I have modelled the HVAC duct, with contains about 12 openings as shown in the attached figure. In order to post-process using 'sample', I have created stl meshes at these openings to calculate mass flow rate using 're-sample with dataset' >calculator > integrate variable. In the calculator option I have multiplied U * rho , and then integrated this using integrate variable to get mass flow rate at all openings. Now the problem is my mass flow rate at the top inlet at fan location is about 18.5 kg/sec and sum total of mass flow rate at all outlets is about 35 kg/sec. Doesn't these two should be equal in steady state for conservation of mass...
Please help me to identify the mistake in modelling..
Regards,
Manoj
manoj_nav is offline   Reply With Quote
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet coolcrasher OpenFOAM Post-Processing 7 November 4, 2021 05:57
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Match mass flow rate with inlet pressure and outlet pressure vut Main CFD Forum 9 February 21, 2014 19:07
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
