Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Wrong yPlus calculation in OF 3.0.1?
Old   March 3, 2016, 09:16
Default Wrong yPlus calculation in OF 3.0.1?
Alex
Kina is on a distinguished road
Hi there,
I am currently investigating the flow around a flatback airfoil and I have built a script that calculates the flow and mesh data for me and puts it into a usable BlockMeshDict file. My calculated first cell layer height correlates well to the CFD Online yPlus calculator so the mistake should not be in my formulas. When I view the mesh in ParaFoam and take the ruler to measure my first cell height it also correlates well to the input data.
However, when I use the yPlus command, I get values of 3 to 3.5 whereas my input y+ is 1 or lower.
Also, the wall shear stress calculated by OF is about 70 times higher than the shear calculated by the Schlichting formula.
Does anyone know the physics behind the OF yPlus calculation?
I am using the yPlus command for t=0 so the values should match my estimation with the initial conditions.
I am using incompressible pisoFoam with kOmegaSST model.
Cheers
Alex
Kina is offline   Reply With Quote
Old   March 7, 2016, 05:01
Default yStar value instead of yPlus
Fabian Roesler
fabian_roesler is on a distinguished road
Hi
OpenFOAM is actually calculating a yStar value instead of yPlus. This can lead to different values.
Check this link:
http://www.cfd-online.com/Forums/ope...lus-ystar.html
Cheers
Fabian
fabian_roesler is offline   Reply With Quote
Old   March 7, 2016, 05:41
Alex
Hi Fabian,
thanks for you reply! So even if OF is saying 'yPlus', it's just the y* value?
That's still a little confusing.
I thought they would have sorted that out by v3.0.1.
Cheers
Alex
Old   May 18, 2016, 05:22
Paul Palladium
Fauster is on a distinguished road
Hi !
I am a bit lost (I am a beginners with OF). I read all these threads about yplus calculation with openfoam but I still don't know how to calcul y+.
I understand that the command yPlus compute y* and not y+. Then I download the utility of Mojtaba.a on post 8. But how it works ? What do I need to do ? I try to replace in
openfoam30/src/postProcessing/functionObjects/utilities/yplus but without success
I guess I need to recompile openfoam. How can I do that ?
Thanks for your help !
Fauster is offline   Reply With Quote
Old   September 7, 2016, 06:19
Paul Palladium
Still any idea about how to use this utility ?
Old   September 8, 2016, 10:31
Paul Palladium
I guess I found out how to install/compile this application.
1. replace the old directory "yPlus" (locate at openFoam30/applications/utilities/postProcessing/wall) by the new one :
https://github.com/OpenFOAM/OpenFOAM...ing/wall/yPlus
2. go in the directory "make" (openFoam30/applications/utilities/postProcessing/wall/yPlus) and type
wmake
Maybe it's better to recompile all the applications by lauching Allwmake in the directory applications. I can't tell you.
Old   December 17, 2016, 09:40
Bashar
Bashar is on a distinguished road
Thanks for the information.
Sent from my iPhone using CFD Online Forum mobile app
Bashar is offline   Reply With Quote
Old   January 27, 2017, 11:53
Default Help with Y+ openfoam 4.0
Fredi Cenci
fredicenci is on a distinguished road
Hey guys, I've been trying to simulate the flow over a 3-D cylinder. I am using wall functions and it is known that Y+ should be 30 < y+ <100 not over 300. I used this calculator http://www.pointwise.com/yplus/ to estimate my first cell hight.
Well, I used the function yPlus in Openfoam 4.0 and seems like the results are different from what I calculated. I've taken a look over this issue, seems like y+ in older versions of openfoam is actually y* and I believe that this is my problem.
How can i get out of this? should I stick with y* and control the y* of my mesh instead y+? which is the ideal value of y* for wall functions?
Thanks a lot.
fredicenci is offline   Reply With Quote
Old   February 1, 2017, 23:04
Default File
Fredi Cenci
Hey guys, I couldn't find the directory (openFoam30/applications/utilities/postProcessing/wall/yPlus). I guess I can't find it because i am using OpenFoam 4.. Do you know where is the directory of the file that I should replace?
Thanks a lot!
Old   April 30, 2017, 13:00
Retired Super Moderator
Bruno Santos
Greetings to all!
I'm late to the following questions, but since I did some research into this, here are the answers:
In this thread: y+ and y* issue - is mostly explained what is y+ and y* for.
From what I can figure out, the y* is the approximation made to y+ based on the wall function values. This also means that it your cell on the wall is large enough and has a y* or y+ high enough, the wall function has to approximate the result either way. But if the cell is small enough, the layer being modelled is for the laminar sub-layer, in which case the y+ calculation is more appropriate, i.e. based on the wall shear stress.
The possible reason that OpenFOAM does not provide the y+ definition, is most likely because the wallShearStress application (OpenFOAM version 2.4.x and older) or function object (as of OpenFOAM 3.0.0, if I'm not mistaken) provides a more accurate depiction of the context in which is should be used, i.e. laminar flow, at least as far as I can figure out (please correct me if I'm wrong).
You don't need to place it inside OpenFOAM's source code folder. You can place it in the OpenFOAM-assigned user folder and build it there. If you don't know where the user folder is located, run:
echo $FOAM_RUN
and it's the parent folder of the "run" sub-folder.
Best regards,
Bruno
komega sst model, openfoam, wall shear stress, y+ value, yplus
Wrong calculation of y+ in flow over backward facing step hedi-72 OpenFOAM Post-Processing 0 January 26, 2016 12:02
Wrong interface curvature capturing and contact line calculation at low capillary nu Mahmoud_aboukhedr OpenFOAM Running, Solving & CFD 0 April 14, 2015 15:04
Increase in CPU number during the FIRE calculation amin_u50 AVL FIRE 0 August 6, 2014 09:34
Solver Yplus of Automatic wall treatment justjhy CFX 2 May 4, 2013 08:19
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 07:07
