Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Measure the surface of the faces of a triangulated cutting plane
Old   February 17, 2016, 11:07
Default Measure the surface of the faces of a triangulated cutting plane
Matteo Cerminara
Pagoda is on a distinguished road
Dear Foamers,
I am using the cuttingPlane class to evaluate integrals over a slice of the three-dimensional domain.
I need to use cuttingPlane itself, not function objects, because I have to take the slice only on a subset of the whole domain.
My problem is how to measure the surface of the portion of plane inside a prescribed cell.
To be more clear, given the cell indexes of the domain subset "subSetCells", and a field to be integrated "U", this is the code I use:
\\ plane base point and vector
point pt(0,0,1);
dir (0,0,1);
plane pln(pt, dir);
\\ cutting plane triangulated (true), over a mesh subset
cuttingPlane cutPln(pln, mesh, true, subSetCells);
labelList cutLabels = cutPln.cutCells();
\\ loop over all the cut faces
scalar US(0);
scalar S(0);
forAll(cutLabels, labelI)
    scalar ui = U[cutLabels[labelI]];
    scalar Si = ???????     // this should be the surface of the triangulated plane
    US += ui*Si;
    S += Si;
US /= S;
Any idea?
Kind regards,
Matteo
Pagoda is offline   Reply With Quote
Old   May 12, 2017, 16:10
Default I have similar problem
Ashish Kumar
ashish.svm is on a distinguished road
I want to calculate the area of the plane of intersection in a grid block.
For example, if blockMesh is used then I want to find out the area of the plane of intersection with a cube.
ashish.svm is offline   Reply With Quote
Old   August 20, 2018, 09:08
Gary is on a distinguished road
Hi Have you found the solution to your question?
Regards, Gary
Gary is offline   Reply With Quote
Old   August 20, 2018, 10:51
Ashish Kumar
Regards, Gary
Not yet
For the time being, I have simplified my problem to focus on simple geometry. But I would be happy to get some idea to solve this
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
