Problems generating xy files after executing foamLog |
January 28, 2016, 12:54 |
ArielJ
Rep Power: 11 |
Hi everyone,
I am running a case for a simple wave tank to using the application waveFoam (https://openfoamwiki.net/index.php/Contrib/waves2Foam). I am running the case successfully and outputting to a logfile. However, when, after running, I execute: foamLog log.wavefoam I get the following output: Code:
Using: log : log.waveFoam database : /home/ariel/OpenFOAM/OpenFOAM-2.3.0/bin/tools/foamLog.db awk file : ./logs/foamLog.awk files to : ./logs Executing: awk -f ./logs/foamLog.awk log.waveFoam awk: ./logs/foamLog.awk:11: alpha.waterCnt=0 awk: ./logs/foamLog.awk:11: ^ syntax error awk: ./logs/foamLog.awk:12: alpha.waterFinalResCnt=0 awk: ./logs/foamLog.awk:12: ^ syntax error awk: ./logs/foamLog.awk:13: alpha.waterItersCnt=0 awk: ./logs/foamLog.awk:13: ^ syntax error Generated XY files for: alpha1Max alpha1Min alpha.water alpha.waterFinalRes alpha.waterIters contCumulative contGlobal contLocal CourantMax CourantMean executionTime pcorr pcorrFinalRes pcorrIters p_rgh p_rghFinalRes p_rghIters Separator Time Ux UxFinalRes UxIters Uy UyFinalRes UyIters Uz UzFinalRes UzIters End I've had this issue in the past with not being able to properly generate xy files but I never sorted it out! Does anyone have advice on this? |
September 18, 2016, 05:52 |
Same Problem
Hey
I've got the same problem. Do you find a solution for it? Thanke you |
October 15, 2023, 12:06 |
Solution
Sarah Aguiar
Rep Power: 3 |
Did you guys find a solution?
awk file, foamlog, function object, post processing |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
Problems with result files | Kasper | CFX | 5 | December 14, 2006 03:41 |
Problems with exporting and importing CAS files .. | Danny | FLUENT | 0 | September 16, 2005 11:47 |
problems with .RSI files | Vladimir Krejci | Siemens | 0 | October 29, 2001 07:29 |
Problems with .bnd files | Thomas | Siemens | 6 | July 31, 2001 17:44 |
