writing out pressure values from OF Simulation |
December 22, 2015, 10:17 |
Rep Power: 11 |
I have just made with the simpleFoam solver and got a p-File with all pressures values for all aircraft faces. In the snappyHesMEshdict, I splitted the aircraft in two patches with the first patch(coarser mesh) being the fuselage and the second (finner mesh) being the wing , for I was more interested in the pressure distribution on the wing. By default , OP writes out the p-values for the whole aircraft . My question is how to go about letting OP writes out the p-values in a separate ascii-file only for the wing. Best Regards Gillers |
January 15, 2016, 20:36 |
Davi Barreira
Rep Power: 12 |
Use the "sample" utility together with a sampleDict to extract the information from the surface you want. There is an example in the motorbike tutorial.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 12:27 |
