Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
extracting phi along a line
Old   November 25, 2015, 12:53
Question extracting phi along a line
Zen
Zeno
Zen is on a distinguished road
I have a straight pipe simulation and I'd like to extract the values of phi along a line that starts at (x1,y1,z1) and ends at (x2,y2,z2).
This is possible for a volScalarField (e.g. epsilon, p, omega, k) and for a volVectorField (U) (but not for a surfaceScalarField as phi) by using sampleDict.
I guess this is because phi is defined at the face centres wheres the other quantities are defined at the cell centres.
Is there a way to overcome this problem?
Thanks for your attention!
Z
Edit: Maybe it can be done with 'probes' as a function in controlDict. A result is output but I'm wondering how this is computed. Why does 'probes' output a result for a surfaceScalarField whereas it is not possible to get it with sampleDict? Is there a way to specify the probeLocations as a file and not as a list of points?
Zen is offline   Reply With Quote
phi, sampledict, surfacescalarfield
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
