Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
interPhaseChangeFoam: velocity non zero at wall
Old   July 4, 2015, 19:05
Default interPhaseChangeFoam: velocity non zero at wall
alvaro
alvariten is on a distinguished road
Hi all,
I'm studying a cavitation phenomena in an axisymmetric nozzle. The point is, when I plot with paraview the velocity values at outlet (and in any section of the nozzle), I saw the velocity is not zero at wall. The velocity profile looks like a normal profile of a fully developed turbulent flow, with a high tendency to zero close to wall. But the value of the node in the wall is about 50 m/s (it being the maximum profile velocity is around of 300 m/s). I do not think the problem is due to the cavitation zone, as even under these conditions, the velocity imposed on the wall is zero (by definition at boundary).
Most likely this is due to the mesh, but I tried it with a very fine mesh and nothing... I ran the command "yPlusLES" and "yPlusLES -compressible" (as I saw in other thread) to see if the refined mesh was small enough, but doesn't work due to there are two phases defined in transportProperties (correct me if I'm wrong please).
Does anyone have any idea why this happens? And how I can be sure that my mesh is fine enough?
Any suggestion is welcome. Thanks.
Regards.
alvariten is offline   Reply With Quote
Old   July 5, 2015, 17:33
Alexander Bartel
alexB is on a distinguished road
Hi alvaro,
some time before I read about similar problems, when accidently have selected the internal mesh instead of the boundary.
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
alexB is offline   Reply With Quote
Old   July 6, 2015, 07:17
alvaro
Hi Alex,
Thanks for your reply. When you say "accidently have selected the internal mesh instead of the boundary" what you mean exactly? What I understand due to your answer is when I select to plot over line in a determinate face in paraview, we select the internal face and we are not considering the patch wall values. So that could be why my velocity values are not zero, but clearly values tend to zero, and the difference between the maximun values of the velocity profile and the values ​​at the walls of nozzle is about 2 or 3 orders of magnitude, then I can give as valid the results.
Regards.
Alvaro.
Old   July 6, 2015, 10:02
Alexander Bartel
Hi alvaro,
I thought you didn't meant plot, but the ordinary visualization of the mesh...
I tested the plot over line command right now... I think someone else more experienced with it could help you better
regards
Alex
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
I want to the velocity vector for the first node point to the wall. Can I use wallDis catapult OpenFOAM Programming & Development 0 January 13, 2012 09:25
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
A girl fail to plot velocity profile when mesh changes + Wall function asherah STAR-CCM+ 0 February 19, 2010 18:45
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
