June 19, 2015, 07:08 |
compare results from two meshes
Simon Grützner
Rep Power: 11 |
Hello FOAMers,
i have a problem at hand, which I have not been able to solve yet. I built an OpenFOAM case and then used refine mesh to create a second case. Now, I want to compare both results in Paraview. Here I was wondering, if it is at all possible to calculate absolute values of the difference between results from the coarser mesh and those from the finer one for every cell and at every time step in Paraview. This should look something like u_diff = abs( u_case1 - u_case2). I am not sure, if I have to use something like mapFields before, to map the data of the coarser mesh onto the finer one, and if so, how it is done for every time step? I really appreciate any help on that matter. Best regards, sgr. |
June 25, 2015, 06:45 |
Rep Power: 15 |
Hi
I have a way but it is perhaps not the best. 1. Patch the results of case A to Mesh B. (mapFields) in case mesh is not 100% identical 2. Do FoamToVTK 3. In Paraview you can now do A-B using the python calculator. Select both vtk files and then do inputs[0].CellData['Results']-inputs[1].CellData['Results'] Br Christian |
June 26, 2015, 12:17 |
Simon Grützner
Rep Power: 11 |
Hello Christian,
thank you very much for your response, it is the first i got at any of my threads. So thank you for that:-) I tried mapFields a couple days ago but I ran in some difficulties, I was not able to solve and which I do not really understand, yet. But perhaps you can help me with that. I have to regions in my domain, named plate and air, since I want to do a conjugated heat transfer analysis between a hot gas stream and a plate. Therefore I used the chtMultiRegionFoam. I basically started from the chtMultiRegionHeater tutorial and adapted the geometry, accordingly. If i use mapFields on the region air, it only returns the values on the boundary and NOT the internalFields, which i am interested most. I used the following command mapFields -consistent -sourceRegion air -targetRegion air and defined the source Time through in the target case's controlDict. Do you have an Idea, what could be the problem here or did you perhaps ran into similar problems at one time? I already tried doing all the operations i did for my case - except the multiregion feature- with the libCavityCase, where mapFields worked fine. Best Regards, Simon ps. I can sent you my caseDir if you like but i had to change chtMultiRegionFoam solver such that I had to uncomment one include in the beginning. |
June 29, 2015, 09:37 |
Rep Power: 15 |
Hi Simon
are the meshes 100% the same, else i don't think you can use "-consistent" mapFields -consistent -sourceRegion air -targetRegion air I use "-consistent" for filling sims when i enlarge the domain with a higher bath Level. Then my meshes are 100% the same. So if you did not yet try without these Option. Hope that will help else i have no clou what the Problem could be. i use always an empty map file, too. (i am using 2.3.X and 3.1-ext) FoamFile { version 2.0; format ascii; class dictionary; location "system"; object mapFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // patchMap ( ); cuttingPatches ( ); Br Christian |
July 1, 2015, 06:38 |
Simon Grützner
Rep Power: 11 |
Hello Christian,
thank you again for your answer. I already tried what you recommended, but it did not work either. And since the second case is just the first one, but with a refined mesh, they should be 100% the same. I do not have a clue, either. I now decided to use "sample" to read out some data and use those to compare the data sets. It it not what I hoped for, but at least something. Thank you again for your posts. Have a nice day Simon |
calculater, paraview, refine mesh |
Comparing Air numerical results with water experimental results | cristian2009es | Main CFD Forum | 1 | July 2, 2014 18:11 |
[OpenFOAM] [Paraview] Compare results with reference | maximsch2 | ParaView | 1 | January 29, 2011 13:21 |
Different results from similar quality cfx and ICEM meshes | Nick R | CFX | 3 | January 17, 2011 07:48 |
Results compare Star cd V4.06 and 3.26 | Andrea | Siemens | 2 | November 11, 2008 03:03 |
[OpenFOAM] Is that a circle Results from interFoam | sega | ParaView | 2 | May 8, 2008 02:49 |
