Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallGradU at runtime
Old   June 5, 2015, 00:56
Default wallGradU at runtime
kkpal is on a distinguished road
Dear all,
In order to calculate the instantaneous total force, which is composed of pressure force and shear force on the surface of the body, I need to obtain the pressure(p) and friction\partial u/\partial y on the surface. The former could be easily done by including a surface probe function in the controlDict. However, there seems to be no such function for obtaining the friction distribution at runtime. Only some post-processing tools like wallShearStress, wallGradU are available. Could someone give me some hints about how to obtain the runtime wallGradU ?
best,
kkpal is offline   Reply With Quote
Old   June 8, 2015, 10:48
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Is there any particular reason you do not use the forces functionObject? It does calculate those forces instantaneously for you.
Regards,
Tom
tomf is offline   Reply With Quote
Old   June 10, 2015, 12:55
Hi, in order to use the functionObject, I need to write down all the files at time interval that is small enough and do the postProcessing with these written files. In the case of large mesh, it would be prohibitive because writing large amount of data to disk is time and disk space consuming. That's why I need to use a runtime utility of wallGradU.
With the extensibility of OpenFOAM I'm sure one could do some programming to achieve this... Could someone give me some hints on this?
Originally Posted by tomf View Post
Regards,
Tom
Old   June 10, 2015, 13:02
Tom Fahner
The functionObject is executed at runTime, that is the whole point of the functionObjects.
Just use it like this (in the functions part of your controlDict):
    forces_Total
        type forces;
        functionObjectLibs ("libforces.so");
        patches
           <yourPatchNames(s)>
        rhoName        rho;//rhoInf; (rhoInf for incompressible)
        pName           p;
        rhoInf             1.225;
        CofR              (0 0 0);
        outputControl  timeStep; //This says to execute every timeStep!
        outputInterval  1;
        log                 false;
This will give you a contiuously updated file with the pressure viscous (and porous) forces.
Regards,
Tom
Old   June 11, 2015, 03:49
Hi, Tomf,
I made some mistakes in the previous post, I was a little dizzy when I was writing that yesterday
I now realize that the functionObject is the thing I needed to output the total or averaged viscous force on the wall. Thank you.
However, the problem I'm facing is one step further. I need to calculate the sectional viscous force on a circular cylinder, since this cylinder is 3 dimensional(waviness or taper in the span-wise direction). The available functionObject will only give the mean viscous force of the whole cylinder.
This is the question that is haunting me. Sorry for the vague illustration in the previous posts.
Old   June 11, 2015, 04:17
Tom Fahner
Well, there is actually the "bin" functionality, which gives "sectional" output, just add it to the functionObject description.
This was released in version 2.2:
http://www.openfoam.org/version2.2.0...processing.php
    binData
        nBin        20;
        direction   (1 0 0);
        cumulative  yes;
You may want to google for some examples/more descriptions.
Old   June 12, 2015, 20:56
Wow, that's exciting! I will try that out!
thank you, Tom
runTime deji OpenFOAM 2 January 17, 2019 10:14
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 05:40
getting (0 0 0) wallGradU value when i m probing wallGradU at some points suryawanshi_nitin OpenFOAM 1 December 9, 2013 12:36
Runtime modification of a volScalarField Scofield OpenFOAM Programming & Development 4 October 1, 2013 09:31
runTime out of scope in functionObject Sune OpenFOAM Programming & Development 2 September 26, 2012 03:11
