Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to get pointDisplacement for chosen patch
Old   April 21, 2015, 06:50
Default How to get pointDisplacement for chosen patch
David Lefebure
DavLef is on a distinguished road
Hi everyone !
I'm a beginner who learned OpenFoam (2.0 version) basis two month ago. I am working on VIV with flexible cylinder structure in a flow and I have two simple questions about things I didn’t find on the internet.
1. The oscillatory amplitude of my one-degree-of-freedom system is an important parameter I need to get for my study. I’m used to generate a forceCoeffs file and I would like to know if a similar file giving a point displacement of a chosen patch is possible (I’ve been using paraview to save pointDisplacement datas but it needs to write folders and takes a lot of time and hard disk space).
2. My study implies to know about some external forces effects on my mass-spring system. I am currently using sixDoFRigidBody function to simulate a linear spring with two parameters : spring and stiffness. I would like to know if it’s possible to generate a « housemade » force function with new parameters.
Thank you,
David
DavLef is offline   Reply With Quote
Old   May 8, 2015, 05:29
David Lefebure
Any suggestion ?
cylinder, forcecoeffs, openfoam 2.0.x, pointdisplacement, viv
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
