Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Parallel Simulation Data Write Failure
Old   April 1, 2015, 11:38
Post Parallel Simulation Data Write Failure
N/A
kamakura117 is on a distinguished road
After decompose a geometry with "scotch", using "decomposePar", running the simulation with "mpiexec -n 6 interFoam -parallel", then using "reconstructPar" I get the following error:
wrong token type - expected Scalar, found on line 29397 the punctuation token ','
file: /home/jesse/NotSynced/VOFCriticality/fill/processor5/74/omega at line 29397.
    From function operator>>(Istream&, Scalar&)
    in file lnInclude/Scalar.C at line 93.
FOAM exiting
When I look into the field file, I notice that a value in the field data has been replaced with a ",". It looks like there was a write problem when running the simulation. On my laptop, I have the same issues. This only occurs when I perform mutlicore simulations.
I am using 2.3.1; however, this occurs with 2.3.0 as well.
My decomposeParDict file is:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      decomposeParDict;
numberOfSubdomains 6; //number of cpus you'll use
method scotch; //method of decomposition
simpleCoeffs
n ( 2 2 2 );
delta 0.001;
hierarchicalCoeffs
n ( 1 1 1 );
delta 0.001;
order xyz;
scotchCoeffs
processorWeights
1
1
1
1
1
1
manualCoeffs
    dataFile        "";
distributed     no;
roots           ( );
kamakura117 is offline   Reply With Quote
Old   April 3, 2015, 13:09
N/A
Has anyone run into this issue at all? I'm wondering if it might be necessary that I use a server with ECC RAM or something, or if there is another trick to protect the writing.
I attempted to use the compression open, but it does not alleviate my issues.
Any help would be appreciated.
Thanks.
Old   April 16, 2015, 16:24
N/A
In the event anyone has this kind of problem, I solved it by recompiling MPI and OpenFOAM. It seems likes something funny happened in the libraries. Luckily, it does not appear to be a hardware issue.
decomposepar, error, reconstructpar
Transfer of data from one simulation to another. sreekargomatam FLUENT 2 January 1, 2015 12:23
Understanding CFD Tracer Study Simulation Data Tracer FLUENT 2 October 15, 2014 14:20
Averaging in parallel - Simulation slowed down fs82 OpenFOAM Running, Solving & CFD 0 March 10, 2010 05:16
parallel mode failure in 3ddp but not in 2ddp ak6g08 FLUENT 1 September 22, 2009 07:56
parallel mode failure in 3ddp but not in 2ddp ak6g08 Fluent UDF and Scheme Programming 0 September 22, 2009 07:16
