Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Run time post processing vs Post run post processing
Old   February 19, 2015, 14:02
Question Run time post processing vs Post run post processing
Pruthvi
pruthvi1991 is on a distinguished road
Hi all.
I'm simulating a flatplate in cross flow using pimpleFoam. My mesh seems to be fine. I got the results for Cx and Cy and later on decided to use a different value of Aref. So I changed the Aref value and ran execFlowFunctionObjects to calculate the force Coeffs. The results I got are not as expected. To depict the difference in results I used the same scale as was used for run time postprocessing and plotted the results again.
Take a look at the plots below. I'm unable to explain why the periodicity of the force Coeffs has changed. Both graphs should be the same instead they are different.
I'm also adding residual data and a checkMesh log.
forceCoeffs.txt
pruthvi1991 is offline   Reply With Quote
Old   February 19, 2015, 15:15
Default Found the answer
Pruthvi
I found the answer guys. Run time post processing has access to all the timesteps. Post run post processing has access to only the written time steps. Sorry for the post.
execflowfunctionobjects, forcecoeffs, pimplefoam, post procesing
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
[solidMechanics] solidMechanics gear contact in rotation nlc OpenFOAM CC Toolkits for Fluid-Structure Interaction 3 January 11, 2015 07:41
[Q] CHEMISTRY POST PROCESSING takes a long time... Whitebear CFX 3 August 8, 2014 10:39
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
time step directories naming issue Andrea_85 OpenFOAM 3 April 3, 2014 09:38
