Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Run time post processing is crashing pimpleDyMFoam for a plunging airfoil
Old   October 8, 2014, 04:51
Default Run time post processing is crashing pimpleDyMFoam for a plunging airfoil
Pruthvi
pruthvi1991 is on a distinguished road
Hey guys. I'm using openfoam230 to simulate a plunging airfoil. The simulation runs perfectly fine without the forceCoeffs function. The moment I add the function, it crashes. I get different error messages for different number of cores. Please help me out. For a certain case I managed to run the simulation for 3 cores. It crashed for all other choices including 1 core. I'm unable to figure out what is causing this error.
I'm giving the link to my github account where the case file exists exactly as I tried to run it. https://github.com/pruthvi1991/pimpl.../onemeterplate
CheckMesh log file :
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : checkMesh
Date : Oct 08 2014
Time : 03:24:59
Host : "ubuntu"
PID : 30815
Case : /home/jujja/GIT1/pimpleDyMFoam-Tutorials/onemeterplate/snappy
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 1924500
internal faces: 1760223
cells: 611384
faces per cell: 6.02686
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 605816
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 5568
Breakdown of polyhedra by number of faces:
faces number of cells
6 184
9 5296
12 87
15 1
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
topAndBottom 160 324 ok (non-closed singly connected)
inlet 962 1153 ok (non-closed singly connected)
outlet 962 1153 ok (non-closed singly connected)
symFront 78407 79395 ok (non-closed singly connected)
symBack 78410 79398 ok (non-closed singly connected)
wing 5376 5544 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-4 -6 -0.1) (14 6 0.1)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (3.98309e-17 -3.13155e-18 -9.03582e-16) OK.
Max cell openness = 3.69726e-16 OK.
Max aspect ratio = 5.59099 OK.
Minimum face area = 4.43241e-06. Maximum face area = 0.08302. Face area magnitudes OK.
Min volume = 3.45928e-08. Max volume = 0.0124572. Total volume = 43.1991. Cell volumes OK.
Mesh non-orthogonality Max: 45.6781 average: 3.68824
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 1.80463 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Here are some pics of the Mesh
controlDict file:
libs
"libOpenFOAM.so"
application pimpleDyMFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 3000;
deltaT 1e-1;
writeControl adjustableRunTime;
writeInterval 4.1665;
purgeWrite 0;
writeFormat binary;
writePrecision 10;
writeCompression on;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 0.9;
functions
#include "forceCoeffs"
forceCoeffs file:
forceCoeffs
// type forceCoeffs;
type forces;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
timeInterval 1;
log yes;
patches ( "wing.*" );
pName p;
UName U;
rhoName rhoInf; // Indicates incompressible
log true;
rhoInf 1; // Redundant for incompressible
liftDir (0 1 0);
dragDir (1 0 0);
CofR (0.2285 0 0); // Axle midpoint on ground
pitchAxis (0 0 1);
magUInf 0.03854;
lRef 1; // Wheelbase length
Aref 0.0457; // Estimated
binData
nBin 20; // output data into 20 bins
direction (1 0 0); // bin direction
cumulative yes;
To prevent the post from getting too long I have attached the error logs for 1 and 8 cores. Please check them and help me fix this problem. Thanks. http://www.cfd-online.com/Forums/att...1&d=1412753744
pruthvi1991 is offline   Reply With Quote
Old   August 31, 2015, 14:44
kkpal is on a distinguished road
I also have this problem when I put binData in the controlDict when running pimpleDyMFoam.
binData works fine in the static cases where pimpleFoam is used.
Have you solved this problem?
kkpal is offline   Reply With Quote
Old   September 4, 2015, 01:31
Pruthvi
Hello kai,
Which version of OpenFOAM are you using? This error is a bug fixed by a commit. If you have 2.3.X you should be fine. Just update your OpenFOAM if its older. Let me know if the bug persists.
Thanks,
Pru.
forcecoeffs, openfoam2.3.x, pimpledymfoam, post procesing, run time
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 11:54
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
