Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
problems with calculating pressure coefficient
Old   October 7, 2014, 03:33
Default problems with calculating pressure coefficient
Elvira
Ernie10 is on a distinguished road
Hey
I'm simulating a flow around a NACA-profile. For this I want to calculate the pressure coefficient cp. I already added the following lines in my controldict:
pressureToolsl
type pressureTools ;
functionObjectLibs ("libutilityFunctionObjects.so");
calcTotal no;
calcCoeff yes;
Did I forget anything?
when I try to calculate this there are problems with the freestreampressure pinf.
My boundary say that I've got a velocity at the inlet and a pressure at the outlet given.
so how can I change my files to get the pressure coeffient?
hope you understand my question
thanks at all
regards Ernie10
Ernie10 is offline   Reply With Quote
Old   October 7, 2014, 08:59
James Rodgers
jrwrodgers is on a distinguished road
Hi Ernie,
I'm by no means an expert but when through a similar exercise a week ago. I found that to calculate the coefficients both static and total you need to specify the reference static pressure and reference velocity within the pressureTools {}. OF didn't pick up the values from the boundary conditions. I think I ended up specifying also the reference density although this is superfluous for the incompressible simulation I was running.
Cheers,
James
jrwrodgers is offline   Reply With Quote
Old   October 7, 2014, 09:49
Elvira
ok that sounds plausible.
do you maybe know how I can tell OF to take the information about the pressure and velocity both at the inlet?
cheers
boundary condition p, freestream pressure, pressure coefficient
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
the pressure coefficient vs angle in CFX?? Jwolf CFX 1 December 14, 2012 08:31
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
