clarification about constant heat flux boundary condition at wall in fluid region |
September 28, 2014, 14:48 |
baran
Rep Power: 12 |
Greeting all,
I have some silly doubt....regarding postprocessing utility wallHeatFlux...it was unable to read my bc at wall of const heat flux in fluid region and it read it as zero.... https://www.dropbox.com/s/1k095xfi7e...subir.zip?dl=0 I am using this command... wallHeatFlux -region cavityAir wallHeatFlux -region cavityAir -time 4000 Can anyone kindly specify me that what is the problem here...about constant heat flux at wall bc..? regards, baran Last edited by baran_foam; September 28, 2014 at 15:03. Reason: link is broken |
September 28, 2014, 15:27 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Baran,
Thanks for posting this question here in the public forum, since this question can help others in the future. I took a somewhat quick look at this case and there is something strange I saw: the wall patches "w_he_*" in the region "cavityAir" are defined as boxes. In other words, each one of these patches is defined with 6 sides, making it a closed surface. in theory, this shouldn't be much of a problem, but it could lead to one of those situations where it cancels each other out. Now, I took a better look at the boundary conditions and in the file "0/cavityAir/T" is this: Code:
w_he_4 { type compressible::turbulentHeatFluxTemperature; heatSource power; q uniform 110.4; K basicThermo; KName none; Qr none; value uniform 300; } Code:
w_he_4 { type alphatWallFunction; Prt 0.85; value uniform 0; } Code:
surfaceScalarField heatFlux ( fvc::interpolate(RASModel->alphaEff())*fvc::snGrad(h) ); Of course now the question is: why is "alphat" zero on these walls? Honestly, I don't know. My guess is that it might have something to do with the fact that you grouped the 6 surfaces into 1 on all of the 4 groups of walls "w_he_*". My advice is what I usually tell people: first test with a simpler case. For example: http://openfoamwiki.net/index.php/Ge..._-_planeWall2D Otherwise, there are too many possibilities for things that could go wrong. Best regards, Bruno |
October 14, 2014, 06:37 |
baran
Rep Power: 12 |
Greeting all,
@bruno ,Thanks for your suggestion... i am trying to use the utility of wallHeatFlux for single wall ...but still it is showing zero value for constant heat flux boundary condition..... Regards, baran |
October 18, 2014, 16:31 |
Bruno Santos
Rep Power: 128 |
Hi Baran,
I simply don't know why this is happening. A few questions:
Bruno |
October 28, 2014, 06:40 |
baran
Rep Power: 12 |
Hello Bruno,
I check tutorial case having simple geometry. It shows the heatFlux boundary condtion as zero value with one face only. Another thing is that it is for laminar case...so may be alphat is not there... So I am trying to check this case with turbulece model.... here alphat is in order of 10^-5 value ...heat flux is giving zero value... Regards, baran Last edited by baran_foam; October 28, 2014 at 07:11. Reason: modify |
November 26, 2016, 18:57 |
alberto
Rep Power: 10 |
Hi
could you find how to put heatflux as Bc? |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Constant Heat Flux Boundary Condition on Long Thin Pipe | CGramlich | SU2 | 3 | April 22, 2013 09:25 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 04:30 |
