Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to output the water resistance on a Ship hull
Old   September 23, 2014, 01:40
Default How to output the water resistance on a Ship hull
Sachin
Sachin m is on a distinguished road
I am working on calculation of water resistance on the hull of a ship. But I could not find a way to output the drag force values. I have been using a function in contolDict which reads as below:
libs
"libOpenFOAM.so"
"libforces.so"
functions
forces
type forces;
functionObjectLibs ("libforces.so");
outputControl timestep;
outputInterval 10;
patches (hull_patch0);
pName p;
UName U;
rhoName rhoInf;
log true;
rhoInf 1025*alpha1*100;
cofR (0.25 0.007 0.125);
Does this function output the force upto the water level of the hull or the complete hull?
Sachin m is offline   Reply With Quote
Old   January 26, 2015, 13:24
Red face no one else interested in this???
sreibisch
Ingenieur5 is on a distinguished road
Hi there,
I have the same task and used the force calculation accordingly. The results seem to be lower than tank test results. The reason I guess is that I am using the bare hull without appendages and without the influence of the propellers. So I am simulating really a towing experiment.
Is there a possibility to add additional resistance to the coefficients for above mentioned things?
Also: What need the center of rotation be like? normally it should be the longitudinal center of the actual waterline to judge about trim, or not?
Hope not to be the only one facing these problems....
Ingenieur5 is offline   Reply With Quote
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 13:08
Flow around ship hull, multiphase setup!! alibul FLUENT 15 February 21, 2019 03:50
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
